Buck Rogers Thunderfighter mods
9,894
Thunder Fighter Cockpit Interiors 2.0 UPDATE!
Hello Ladies and Gentlemen,
I know that it has been a very long time since I have posted anything in this thread. However that does not mean that this project is far from dead.
Revell-Fan was able to finish the revision and clean-up of the cockpit interiors 2.0 kits (for both the two seat and QUAD versions).
I have started with the final test build of the Two seat version.
Here are the photos of the test build.
The tub was lengthened by 5mm.
Here are the parts for the new seats.
New Seats are assembled.
New seat in the tub.
Joystick control console.
Joystick control console in the tub.
9,894
Cockpit interior attached to the top skin.
Side consoles are attached.
Main front console is attached.
Top skin (with the CI) is attached to the rest of the body.
This will be it for this build for now. I will finish this one after I finish the QUAD test build (which will post photos with my next post update).
micahrogers
3,772
4,639
Shannon GA
I truly LOVE these Thunderfighters, R-F's designs and your builds are top notch.
12,353
Thank you, micah! However, RB designed the new CI, I only cleaned the parts up. Let's say, it is a fruitful collaboration! :thumb:
9,894
Quad cockpit
As promised, here is the QUAD cockpit.
Like the two seat version, the parts are very straight forward and easy to assemble.
Here are the photos for your viewing pleasure.
Here is the parts sheet.
Here are all four seats.
All four seats are finished (as you can see, the seat harnesses look a bit more realistic).
Here is then tub.
The center console is in place.
The seats are added.
The horizontal console platform is attached.
9,894
Here are the Joystick mount control consoles.
The Joystick mount control consoles are in place.
Here are the rear control consoles.
Rear control consoles are in place.
Here are the "EXTRA" side control consoles.
9,894
The vertical console is attached.
The "EXTRA" side control consoles are attached.
joysticks are attached.
Additional support formers are attached (which will not be seen once the the cockpit is attached to the top skin).
9,894
Update
Here is an update on my progress.
Here is the top body skin.
The cockpit tub is attached (the side tabs on the vertical panels are trimmed as needed).
The rest of the top skin is built up.
The top skin is attached to the rest of the body.
(NOTE: fitting the tub in place is a bit trick and very tight.)
The front console will go on next after a few minor changes and revisions.
Please stay tuned to your local Earth directorate channels for further updates and they happen.
