Ferrari Engine design and build
Will you have a bigger current load a lower voltage because of resistance from the motor, and will the power supply deliver and or is it self adjustable so it can adjust itself to the given load? It looks great. My wife would kill me if I set up all m equipment. I haven't built doodly in years. :)
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
www.watch_this_space.com
the motor that I am using oddy enough when I was testing the circuits under no load the current did not chnage by much, at 1.5V the current was 115mA and at 6V which is the so called max voltage on the motor at no load it was 125mA when I loaded the motor to the point of near stall at 2.5V the current was 270mA.
The circuit is designed in such away that at any voltage from 0.2V to 15V should the circuit draw 3A it will limit it to 3A's I have set the LM723 up to sense Current and adjust voltage at the same time.
so yes the power supply will deliver the current and voltage at what ever the voltage point is set, the trick is that the power source can deliver the current, so one should make use of a 220Vac to 15Vac or 110Vac to 15Vac transformer with a 4 Amp rating and that will work 100%
If you have 1 Amp Transformer then the max current will be 1 Amp.
Wow, with current sensing, that means if someone wanted, they could set it up to run real slow, all the time. That would be a cool feature. A really slo-mo engine! :)
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Well it is time for an update on the devlopment work of the engine, I have now busy test building the piston, conrod, and cyclinder bore of the engine of which there is a few small mod's needed to get it spot on but here is the photos of the test build parts.
More photos will follow as the build goes on.
R
Reactions: Rhaven Blaack
terrinecold
303
I weighted a piece of 160gr. A4 paper and after doing some sums each A4 page of 160gr. paper is approx. 9.8gr and I would guess the Letter would be about the same.
160g for 1m2 which is A0 format
80g for 1/2 m2 which is A1 format
40g for 1/4 m2 which is A2 format
20g for 1/8 m2 which is A3 format
10g for 1/16 m2 which is A4 format
9.8g is pretty close so I guess the difference is due to lost paper in the cut or to approximations in the initial weight
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
What I did was to take sheets and weight it, and repeat it with 20 sheets then divide it by the quanity of paper that I have weight and worked out to be the answer.
In the case of the model, the model will weight less at the end of the day due to the paper that I am not using, it will insteresting to see what the finished masss is going to be, I am keeping tabs of how much glue I am using as well to see how that effects the mass of the model as well.
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Well Update time !!!
At last I have now completed the 12 pistons, conrods and cylinder bores:cool:
The next step is the block parts like the 7 big ends and some other parts to hold it all together, and then the crank.
Here is some photos of the finished parts:
ENJOY
R
vbsargent
175
3
MD, USA
Wow . . that is just . . . .wow! :eek:
First the design was amazing, now the build is amazing, and youi still got so much more with which to blow us away!
vbsargent
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
I bit of a sneak photo of where I am with the Engine. (crank)
At the moment I am busy figuring out and checking that everything is lining up, and also how I am going to assemble all of the parts to get the block together, at the moment I have had to do a bit space corrections in the block as the crank has come out a bit bigger than I designed so some shiming of the block bores is busy been worked out and the some jigs to assemble the crank is also been worked on.
I did a quick calc of how far I am and it works out to 21% which is fair as I am busy building the model I am also writing the instructions and doing small mods as I go along.
R
9,549
Wow, you have made fantastic progress in this. This becomes a "STICKY". I am about to pull the engine from my 1973 M.G. Midget, thankfully I have already blueprinted it, 3 ring forged pistons, 10 degree cam, polished valves, and DCOE side draft Weber Carburetor. I just got a "like new" transmission. You model really reminds me of the rebuild. You would probably cost cheaper though, mine cost me $5,000 dollars and I did all the work!! :)
12,353
OMG, that's incredible! Will everything move just like on a real engine?
Rogerio Silva
1,520
11
38
56
Rio de Janeiro - BRAZIL !!!
Gee, Man! A "working" paper Ferrari engine? And I thought I'd seen everything...
Speechless, amazed, impressed, you name it, that's how I feel! Fantastic! And that said by someone who dislikes mechanical stuff...
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
I have found the spacing problem, when one builds many of the same part any small size difference in any or all of the parts will show itself at the end of the day, between the crank shells and the conrods I have a 3-5mm error between the piston bores so, what I am having to do is make a 4mm paper shim that will fix the model, but at the same time when people build the model the error could bigger and smaller so the shimming is not a bad idea in getting the engine to work at the end of the day. it just mean that when I get the cyclinder head that I need to re-visit that part of the design, but that is quite some time down the road.
@ Rogerio, thanks, it is a good sign to see people speechless :) :)
R
