30"x48" N setup
Discussion in 'N / Z Scale Model Trains' started by Chad, Dec 21, 2006.
  1. Chad
    Chad Member
    Yes it is, Cat5e sign1
  2. jesso
    jesso Member
    I love what you have done so far! How high are you making the crossover track and what % of grades are you using?
  3. Chad
    Chad Member
    Thanks for the compliments folks!
    The overpass is only high enough to allow for my tallest car under it allowing for the track and roadbed, it's eyballed to about 1/8th of an inch from the top of the tallest rail car. I created a "bridge" from some metal flashing so that it can be thin and strong. It's going to be hidden inside the mountain. I'll try to get a picture of that up today.
    The grades are all 2% EXCEPT for the overpass as there is not enough distance to do 2% and get high enough so it is 4%. The section going under the overpass is 2%. Probably 3% up and down would have been best, but oh well.
  4. Chad
    Chad Member
    ok... here's the "bridge" that will support the train and the tunnel entrances.
  5. Chad
    Chad Member
    Got some more work done today since it was raining out. Most of the track is down :D
    This shows the clearance inside the mountain.
    I broke out a 23 year old Bachman 0-8-0 engine just to take a couple of pictures. I dont have any wiring done yet so nobody drives.
  6. jesso
    jesso Member
    Cool! It is turning out great! I can't wait to see your tunnels and mountains. Just make sure you don't get any automax's or double stacks.
  7. Chad
    Chad Member
    That's okay, no real desire for either ;)
  8. Chad
    Chad Member
    Got my wiring done with no issues :D
    My machines that are 20+ years old don't run so well but the old F deisel runs okay. The Athearn 2-8-0 runs AWSOME. I could not beleive how smooth and quiet it runs! Do all "modern" models run this smooth now?
    Model power has a 4-4-0 American that I like.
    So all the talk about connectors, I just decided that I would just mount the switches on the 1x6 side of the framework. Easy!
  9. YmeBP
    YmeBP Member
    Curious about the use of cat5 i've seen it on a couple of layout photo's on the gauge. How does it stand up to the amperage needed to run switch machines?
    Currently i use 18awg solid copper for track feeder and 14awg for bus. I use 18awg solid copper for switch machines. Been experimenting w/ 16awg stranded, but i see you using these network wires w/ sucess makes me wonder :) am i just overkilling the wiring? I'd live to use thinner wires :) easier to work w/ and i have 2 spools of about 1000feet each solid copper cat5e already.
  10. Chad
    Chad Member
    Ever hear of power over ethernet? 48VDC and 15 watts... I dont expect any problems using cat5. I have used cat5 as speaker cable too.
    24 gauge is ok for 0.577 amps
    If you use two 24 gauge wires it's the same as an 18 gauge wire, 2.3 amps
    Switch machines use such short bursts of power I don't think it's likely to cause an issue,
    The circuits I have are 3 feet or less so voltage drop is not very much, like 0.6% at 12 volts.
    I did use much larger wire to supply power from the dual cab controller.
  11. b28_82
    b28_82 Member
    I forgot that ethernet wire is low loss cable because it's twisted pair. Anyhow I use 22 gage wire for my feeders and i plan to use 18gauge lamp cord wire around my room but then again its only a 9.5x11 room so it wont be much voltage drop. Besides thats the standard for Ntrak and they had over 400 modules w/o a problem but I guess they had a couple power districts and boosters.
  12. Chad
    Chad Member
    Brother... I just started thinking, I have NO bridge. So now I am thinking of building one where the control panel is.
  13. berraf
    berraf Member
    That sounds like an interesting thought :thumb:
    In fact that could be the solution to one of my problems :)
    What type of building do you have in mind?
  14. Chad
    Chad Member
    Timber built. I'll have to look at lots of pictures... and it would have to be two tracks wide.
  15. Cannonball
    OK..... I must be doing something really wrong because I can't get near that many loops in a 3x4 area using RTS. What size curves and straights are you using? I was using 11" curves and 5" straights. Are you going down to 9" curves?
  16. Chad
    Chad Member
    Yes - The inside is 9" and the outside is 11". The line going to the yard uses 9" also. I can send you the RTS file if you like?
  17. Cannonball
    Wow.... Do 9" curves cause any major restrictions? Longer passenger cars won't take them will they? Either way, I'd like to see the file on it. Maybe I can figure out how to work in such a restrictive space. I'll PM my e-mail addy to you.
  18. Chad
    Chad Member
    remember I was shooting for early 1900's so long cars were not my goal.
  19. jesso
    jesso Member
    Cannonball, my N scale layout is all 9 3/4 track and I have run double-stacks, automax's and SD70MACS on it and I have never had a derailment. It even has 4 S-Curves on it and it has never had a problem.
    Chad, are you scratch building the bridge? Are you talking about the curve near your control panel? Can't wait to see it!
  20. Chad
    Chad Member
    Yes - I was thinking of scratchbuilding it, and yes you have the correct location. I just have not designed it yet. I have ordered AutoCad for dummies :)
