Building my own Y wing(s)
dnalor
917
186
Belgium Europe
I hope so..
Every day i sit in front of the tv with this..
And you don't see it grow..that slow it goes...
i hope i don't destroy it when i spray paint it.
dnalor
917
186
Belgium Europe
Almost there...
i can see the end of the first side..finally.
after that i need to go back on the top side to add details because there will be 2 different y wings.
they are small but there.
2365
Reactions: zathros
DanBKing
Dan the Man
Feb 29, 2012
1,817
1,587
Netherlands
The detail is looking great. I'm looking forward to seeing it painted.
Uniform colour will make it kick ass!!:thumb:
leofirebrand
97
I hope so..
Having painted many models I can assure you the paper is far more durable than you would expect, especially after putting on all the little details. To add the mounting rod for my Y-wing I had to get a dremel out by then end.
That said I tend to prefer brush coating over spray cans in most cases. Simply because spray cans are so inconsisten in quality and limited in color. You could probably get away with using a gray primer thought for the Ywing.
Go light on the first coat, once it dries the paint acts as a protective barrier and it paints like a plastic kit.
dnalor
917
186
Belgium Europe
Ok..
the first side panel is almost ready ..
and the back of the two y wings are also ready.
from now on i have to watchout which y wing is the red jammer because the details start to be different.
2665
Reactions: zathros
dnalor
917
186
Belgium Europe
ok side panel complete and attached.
2700
Reactions: zathros
9,898
As always, you are doing a FANTASTIC job on the greebles.
Watching your threads (like this one) is always inspiring and thought provoking.
Keep up the GREAT WORK!!!
ShadowHawk141
167
Netherlands
Man where do you get the patience, it must take hours to get that kind of detail :eek:
It's looking out of this world though, simply fantastic.
And as Rhaven said, your threads are very insipiring.
Cheers,
Elko
dnalor
917
186
Belgium Europe
Well..
Look at the greebling part in sections..
then it is workable.
when you see it as 1 part is just scary.
And maybe i will find the part i can't rebuild in paper..and the project stops...(hope not)
dnalor
917
186
Belgium Europe
I've started with the side panels for the other side.
2848
Reactions: zathros
leofirebrand
97
Looks like they are coming along quite nicely. It must feel good now that you have a whole side complete and are moving on to the next.
dnalor
917
186
Belgium Europe
:) yes it helps a lot to see it grow..
but still i have a long way to go..
also i have to watch out that i do the correct details on the ships..
dnalor
917
186
Belgium Europe
Yes they are ready..
i'm thinking about spraypaint them before attaching to the y wing.
i should have done that to the first side to..
3022
Reactions: zathros
dnalor
917
186
Belgium Europe
I tried the paint..
but it's a bit shiny..
when adding the dirt...would the shinning go down..or should i look for another spraycan?
and i need to cut the glue-strings...they look like spiderwebs
3081
Reactions: zathros
ShadowHawk141
167
Netherlands
Wow, that's realy shiny.
Maybe if when you are ready with the rest of the coloring an overall matt varnish can take the shinyness off ?
Just a thought.
The detailing is great btw.
Cheers,
Elko
dnalor
917
186
Belgium Europe
a few details applyed..
And thinking about a drybrush set.
But i don't know if i use it after this project..
well i still have a few days to think about it :)
3182
Reactions: zathros
micahrogers
3,772
4,639
Shannon GA
Amazing job on the PAIR of Y-Wings, the dirtying up will not by itself get rid of the gloss, plus the shine will make the "Dirt" not want to stick. a good matte clear will get rid of the shine.
