Here is the B5 (Babylon 5) Centauri Vorchan.
Gandolf50 managed to find a copy of a lightwave model. Here's the original post from him from here
http://zealot.com/threads/models-of-merit-bsg-defender.179259/#post-1011869
"Took about 10 minutes to find a 3d model, convert it and here is the result in Pep...( with out any work at all) and It can use some! but it is a start! ( note: this was an open use file)
I will keep looking for a better mesh to work with..but any one that wants this one message me!
Never mind...already found one closing down the search window... this is WAY better file..but will take considerably MORE work to get to paper craft format..and since it is someone else's file..permission will have to be sought! If you have the ability? then http://www.scorpiocgi.co.uk/1333#prettyPhoto you can get the lightwave file and get started on your own...
it does have all the textures and such..this is just the color version of a Centauri Vorchan..."
The resource that was created as a result of his efforts is here in a pdo format:
http://zealot.com/resources/centauri-vorchan-mesh-file.1718/update?update=1758
Looks like it's time to build and modify to the scale of Jaybat's Omega Destroyer see here:
http://zealot.com/threads/b5-ea-omega-destroyer.178700/
and a MUCH better version done by Spaceagent here:
http://zealot.com/threads/babylon-5-earth-heavy-cruiser.178998/#post-1006997
Of course I would be remiss if I didn't mention Lepaj's version here:
http://zealot.com/threads/destroer-class-omega-agamemnon-babylon-5.172825/
MANY Thanks to Gandolf!! :Bravo:
Let the building begin!!
Sky Seeker
:tank:
Sky Seeker
:tank:
