The On30 conspiracy
Hi all!
Pete pointed me over to this thread, & I’ve really been enjoying skimming through it!
I’m pretty new to this On30 thing…I got into it because my poor eyesight just couldn’t deal with the N scale anymore…
I had modeled in HO previous to getting into N scale, so I still have some old HO stuff laying around…
I’ve bashed a couple of HO cars into On30, & I’m having a blast doing this!
I’ve also started a diorama, to give myself a bit of a feel for doing O scale scenery, structures, etc…
I haven’t seen too much On30 stuff being posted over here at The Gauge, so I thought I’d resurrect this thread, to see if there are some others still hangin’ around!
Glad to see your response, Capt!
I really love your definition of On30! :D
Well, I’ve gotten some wood on the little shed I’m building…
I found these windows in the scrap box…they measure 3x3 ft. in O scale…This really puts into perspective the difference between O scale, & N scale, which I’ve been modeling in for the last few years…Those “windows” are actually the garage doors from an N scale gas station kit!
After I finish the plank walls, I’ll have to come up with something to serve as a roof…I’ll get back to ya on that later!
I've built a small station house that I used fine grit sand paper cut into strips and glued on like tar paper. Put a coat of green acrylic paint, and then black along the seams like roofing tar. Came out pretty good. I'm not home where I can take pics.
Looks to me like that would be the perfect kind of roof for that shed.
As far as the scale difference, I have a couple of N scale locos that would easily fit in my little O scale outhouse, with room to spare. :D
N scalers, don't think that is an inuendo. They are just so small!
I’m glad I found the thread, Pete!
I remember this thread from some time back, but I hadn’t yet been “assimilated” at that time! :D
One thing I’m realizing, is that the potential for freelancing, & kitbashing in On30 are limitless!
Like I mentioned, I’ve got some old HO stuff laying around, a lot of it being in the cheapo trainset category, that now I’m looking at as a supply for kitbashed On30 rolling stock…
I’ve built a couple of cars already…
On one, I started with an old HO bobber caboose…
I used it as a starting point for this coal tender…
I also had this old LLcaboose from an old trainset…
I made this little flat car out of it…
I realize that these aren’t the greatest examples of craftsmanship in the world, but I’ve really had fun with them, & hope to do a lot more of them, & hopefully get better at it with practice!
My little flatcar kitbash had kind of come to a standstill whiI worked on some other stuff…
The pieces from the HO bridge kit that I had tried earlier didn’t work out too well…I picked the car up one evening, & the side sills just popped off in my hand, so I replaced them with some plain styrene angle stock…I also replaced the Athearn Bettendorf trucks with some Kadee archbars…
I’m still working on fashioning some stake pockets, stirrup steps, & a brake wheel…
Get back to ya later with that!
Well here are my efforts so far on the stake pockets…
I made them by just cutting 6” slices (O scale) off a piece of brass channel…I compared their size to some stake pockets on standard gauge HO flatcar, & they seem to scale out pretty well…
I still have to cut some more for the other side…
OK…I need some honest opinions…How do these look?
After pouring over catalogs & internet sites, looking for stirrup steps, I decided to go the bargain basement route, & try to make some of my own…I had this steel wire laying around…(I guess it’s somewhere around .030”…?) & I just bent them with some small needlenose pliers, drilled holes in the bottom of the car, & glued them in…
The stirrup steps look OK Drew but are a bit on the heavy side . If you had some smaller diameter wire they may be a bit better as these ones you show look quite massive compared to the wheels.
Yeah, I thought they were a little on the heavy side too...They measure about 2" think in O scale...
I guess I'm guilty of still thinking in N scale, where we get used to having things out of scale sometimes...
I've already gotten these installed, so I probably won't change them on this car, but I thought for the next project, I might try some thin brass strip...
Thanks for the input Robin!
Ky R&A #1 pushes a flatcar carrying some boards up the quarry spur…
Looks like they’re FINALLY going to put a roof on that lineside shed!
