There she is....there she is...not so wounded as we were lead to believe.
9,593
This could be easily fixed by printing out a circular piece and placing a gluing strips (also circular, underneath), the the fixing ring, you would cut back to the first panel line, then glue in the necessary pieces, and when you cut that line, cut on the line, inside the line, or outside the line, but only choose one, not all three!! It should be fixed, then uploaded here. That's more than a 10% fix. :)
Reactions: Rhaven Blaack
Cybergrinder
Member Extraordinaire
Jun 24, 2014
2,384
3,992
Johannesburg, South Africa
I'm still not happy with the outcomes, I tried the "inner ring and cover" solution but it still didn't work. I had already adjusted the rim to align with the upper section only to find that the lower section does not align with the rim and upper section. I think it's just a poorly designed template that (for me) is more frustrating than enjoyable.
