Ss-1c scud b + maz-543
micahrogers
3,772
4,639
Shannon GA
I sent 8 hours detailing and wiring a 1/12th scale 4 cylinder for a commission build that would be hard pressed to look that good. Amazing work that...
9,549
I really like the idea of straight pins for steering knuckles. I may be borrowing that from you! :)
Kiyoshi
69
borrowing is good xD no need to invent the wheel again ;-) It's been a while since I last posted an update, but no worries, still struggling with the model. The drive shafts to be precise. They don't seem to fit :-( So I need to make some changes. Will post more when I have it installed.
Kiyoshi
69
Yay, finally I found the courage to build again xD I don't have many pictures, but I think it shows pretty nicely what I have done so far. I feared the parts wouldn't fit, there are some inconsistencies in the model, but it turned out okay. I do hope that, when I get to work on the bodywork, everything still fits :)
So... time for pictures! (and if something looks lumpy, no worries, everything will get covered up anyway... most of the stuff I did till now (up to building group 128) will be invisible when the model is done).
Because by now I have realized that this is a massive project, I decided to start a smaller project next to it. This time a ship, since I don't have experience with those yet:
Kiyoshi
69
And time for another small update xD I have been puzzled by the model, to be honest, because the building diagrams didn't make enough sense to find out where what part needed to go exactly. So it has been a bit of trial and error.
The numbering on several parts is wrong, and it doesnt make sense, in the building sequence, to build this part first. It will only get added after two two steering cabs have been put into place, and I will be building those next. So... dont glue anything in place yet :p
I did manage to get everything together tho:
Now that I have finished those, it is time to focus on the detailing (these are all made of brass):
The next steps will be to paint all the small parts and to put them into place. I think it'll look cool.
9,549
Watching this come together is a religious experience. :)
Kiyoshi
69
Hehe Zathros, I think this is the first time an atheist causes a religious experience then xD
Anyway, I have some more progress to show. I have been working hard on getting one of the steering cabins done, and the little pieces of the grille.
First: some of the parts needed for the steering cabin:
When I glued the outer shell together, I immediately noticed that one part has the colouring on the wrong side *sighs* swapping it with the same part of the other steering cabin isn't possible, because it's slightly different at the back end.
But well... I have faced worse by now xD So I put in the inside (nice if you like green!). The roof needed to be corrected, it was too wide. I think the designer kinda forgot that the outside part of the roof has a ummm... whatchacallthem... one of those flappy thingies that get used to glue stuff together.
According to the numbering, I should have continues working on getting the structure of the steering cabin done. But, if I had done that, there would have been no way to put in all the little details, for example the wiring (which I took out of a disfunctional spare headlight of my previous car that I didn't throw away yet) which is something like .1 mm thick:
Work on the grille has progressed too. The current state is this:
And a final look at the inside of the cabin, before I put in the floor (including seats) and the side wall, including doors:
