Robin's Outfitters
Discussion in 'Scratchin' & Bashin'' started by Fred_M, Jan 11, 2005.
  1. Fred_M
    Fred_M Guest
    I just used more blocks Dave. Fred
  2. philip
    philip Guest
    Hi Ya Fred,
    How high can you stack those dpm castings? Could you go beyond 4 stories. Great looking modern building to. :thumb:
  3. Fred_M
    Fred_M Guest
    Dunno my friend. I stopped it at 4 stories because it looked right. The building is plenty strong. It's about 5, no 6 years old now. The floors and roof are made of foamcore. What happened to the funny avatar? Fred
  4. philip
    philip Guest
    dunno.............................................................. :cool:
    BTW...did you use dpm windows?
  5. Fred_M
    Fred_M Guest
    The windows are cast into the walls. I used a piece of flat toothpick for the sash between the top and bottom window because it was too small to cast in plaster. It was inserted in the mold where it belongs and plaster was poured in making it one with the casting. Then toothpicks would be inserted into the casting around the windows for rebar and the casting was allowed to cure. Fred
  6. Fred_M
    Fred_M Guest
    Couple of pictures as i continue to work on the deatils. Fred
  7. Will_annand
    Will_annand Active Member
    I must say you do good work my friend. :D
  8. Matthyro
    Matthyro Will always be re-membered
    Beautiful work Fred. The setting is perfect. Looks like one of those hot summer days when everyting slows down.
  9. Tyson Rayles
    Tyson Rayles Active Member
    Very nice Fred!
