Pz.Kpfw.II Ausf.C (Halinski 2-3/98)
snake7
424
1,165
93
46
Israel
I finished to assemble separate tracks into one strip
and in one evening finished to glue the teeth
Now tracks will wait in box for painting job and I, with relieve, can continue the assembling :)
snake7
424
1,165
93
46
Israel
The tracks got paint and lay drying aside
In the meantime I assembled protecting skirting and elevation hooks
The one on rightmost side - gluing place was inverted
Also I glued front towing hooks
snake7
424
1,165
93
46
Israel
Hello to all
Exhaust pipe assembled and glued in place
I did the tubes from wire with isolation, instead of paper ones
Also assebled towing pin
And finally! Tracks are ready, painted and installed
They was painted twice. First time it was metallic steel, but
the color was too bright and shiny. So i did step two and painted over with black matt, very diluted and old paint
For my opinion the result is satisfying
snake7
424
1,165
93
46
Israel
Thank you Janos
Some more small parts
Lights were made with decreased circle method
snake7
424
1,165
93
46
Israel
Some others parts on side shelfs. Arm of the shovel was made from toothpick
snake7
424
1,165
93
46
Israel
Hello
I finished all the instruments on the shelfs
Some instrument boxes, antenna rail and jack rest
snake7
424
1,165
93
46
Israel
Jack and extinguisher
snake7
424
1,165
93
46
Israel
Everything put in place + antenna
snake7
424
1,165
93
46
Israel
Hello!
Last step - turret!
I did it with doors that can be opened so i was in need to glue the reinforcements inside
First the upper and lower, then rear and then side ones.
snake7
424
1,165
93
46
Israel
Then I assembled barrel, gun, front mask and some hatches
snake7
424
1,165
93
46
Israel
And last thing I did was main hatch doors and commander shield with periscope.
When the turret was finished I glued it into turning basis on the hull...
And the model is finished!
snake7
424
1,165
93
46
Israel
Final photo-session
...to be continued in next post
snake7
424
1,165
93
46
Israel
Continued from previous post
snake7
424
1,165
93
46
Israel
continued from previous post
last picture - a bonus
Thank you all, who followed my thread
KCStephens
83
York, PA
Igor,
This is a beautiful model that you have built. I liked it so much that I had to order one for myself. I just love the weathering and textures that are printed on this kit. This will be my next build. I only wish that there was an option in the kit for "band style" tracks...the individual links are killer.
I still may order the laser cut tracks like you did.
cgutzmer
5,242
55
Sun Prairie WI
www.ecardmodels.com
Magnificent! I am just picking this build up again after 3.5 years on the shelf. I am not at the same skill level as you and I dont use paint but I got lots of good tips out of here already! Question - I am at the mudgaurds and had no idea that one sheet was for the inside of them! did you glue it to the bottom BEFORE you cut and folded the parts or glue them to the inside after the parts were formed up. Seems to me you would get a better result doing it first but I am unsure how well folding would go in that case...
Thanks!
Chris
