Next addition to The Academy?
Discussion in 'Getting Started' started by MasonJar, Jun 23, 2003.
  1. MasonJar
    Rather than a poll, as we did last month, I am just asking for suggestions. Dave Hagan has kindly agreed to move any "nominated" threads to The Academy.
    So... if you have a suggestion, please post a link in your response.
    The Academy is an invaluable source of information for all of us here at The Gauge, so let's keep it up to date...
    Here is my suggestion:
    Charlie's Making Styrene Look Like Wood from Scratching & Bashing in May.
  2. Tyson Rayles
    Tyson Rayles Active Member
    I'll second that!
  3. TrainClown
    TrainClown Member
    My 2 cents.
    I have found many posts helpful and inspiring. Here are some of what I consider to be the best.
    Tyson Railes........."N-Scale climax?"
    cacmage..............."concrete arch bridge"
    Woodie................."Rural Agents Pty Ltd"
    shamus................."First 0n30 scratchbuild"
    Matthyro..............."What is it?"
    This is what I think.
  4. Dave Hagan
    Dave Hagan Member
    Just to clarify that all new additions to the Academy will be subject to review. Where a thread is added we will 'tidy' the thread by removing posts not relevant to the article.
    Making Styrene Look Like Wood by Charlie has been approved and added to the Academy.
    TrainClown, you need to supply a direct link to the threads you are nominating.
    Dave Hagan
  5. TrainClown
    TrainClown Member
    Sorry about that :D here I'll try it again.
    Here they are again.
    <--HTML code starts here-->
    <a href=""><b>THE GAUGE-Model Trains-Scratchin' & Bashin'-N-Scale Climax?</b></a>
    <--HTML code ends here-->
    What am I doing wrong? Why didn't this work?
  6. MasonJar
    Here is the format for making a clickable link in your message. To link to this thread, for example:
    <url=>Next addition to The Academy?</url>
    except change the "<" type bracket to the "[" type.
    You then get this:
    To get the proper url, just go to the thread, and then copy whatever it says from the address bar in your browser.
  7. shaygetz
    shaygetz Active Member
    I'm with Trainclown's suggestions...but I'll let him do the hard stuff and figger out howta post 'em:D :D :D :D :p Ain't too hip to all this Trekkie 'puter where did I put my teef....
  8. Drew1125
    Drew1125 Active Member
    I'm quite honored guys...Thanks!
    I also think Tyson's N scale Climax article would be a very nice addition to The Academy.:cool:
  9. Tyson Rayles
    If'n I ever get the durn Climax done I might agree with ya, till then.......................................................:D
  10. rsn48
    rsn48 Member
    Trying to type addresses (URL's) is like threading the needle, frustrating. Best just to do a copy and past, which is a no brainer. If I have several addresses, I will open word or note pad and paste the different addresses there. Then I hit "edit" then "select all" then copy, then paste this copy into the post.
  11. TrainClown
    TrainClown Member
  12. rsn48
    rsn48 Member
    Can you forward these links for next months vote. There are a couple I would like to see in the Academy. But for this month, I'll vote for Charlie.
  13. Dave Hagan
    Dave Hagan Member
    Hi Rick, there's no voting on additions to the Academy.
    We review each thread on a case by case basis and make a decision if it's suitable material for the Academy.
    I've just had time to take a quick look at some of Trainclowns suggestions and I know that some of them won't make it in. The Academy is like a tutorials section and some of the threads don't go into enough detail to be added. Threads added to the Academy have to give step-by-step instruction about techniques, materials used, potential problems, etc
    Dave Hagan
  14. McFortner
    McFortner Member
    Definately "Weathering a truck" by Spitfire (Val). A great how to with pictures! ;)
    Your mileage may vary.
  15. jon-monon
    jon-monon Active Member
    I've set up a sticky in the photography section for posting links to your favorite how-to type threads that don't make it to the academy. Please read the thread before posting links, so we don't have duplicate or unqualified links. Posting a link in the sticky will not have an impact on it being placed in the academy.
    Remember, if you have a thread you want to keep track of that doesn't make it to the academy, and does not qualify to be in the sticky, you can always save it as a bookmark or favorite in your browser.
  16. Benny
    Benny Member
    If you DON't put the "what is this" thread in there, then I don;t know WHAT you WILL put in there!!!
    Though I might recommend Robin writing it up in a more progressive style such as that you might find in a railroad magazine...title it something like "Coaling Towers In Cereal Boxes" or "Working in Cardboard."
  17. shamus
    shamus Registered Member
    All possible additions for the Academy/Archives should be in some form of a tutorial, showing by the use of photographs just how the project was conceived. Also, if at all posiible, no comments should be added to the "How to"
  18. MasonJar
    August Addition?
    Bearing in mind the guidelines from Shamus and Dave Hagan, does anyone want to suggest an addition for August?
  19. Dave Hagan
    Dave Hagan Member
    I know we've been a bit slow dealing with members suggestions to the Academy. With Shamus back on board we'll try to add at least one new thread every week.
    Dave Hagan
  20. shamus
    Weathering a truck by Val has been placdd into the Academy/Archives
    Congrats Val
