Looking at buying flex track.
Discussion in 'HO Scale Model Trains' started by KentBy, Feb 16, 2008.
  1. KentBy
    KentBy GN, NP, SP&S
    Prices (on the Internet) for code 83 NS and for 3 ft pierce (I need 100 pieces) go from about 2.60 to 6.80 each for quantity price.
    I have look at Atlas, Model power, micor engineer, peco, shinohara.
    Is there any other brand the I should consider and why not go with the cheapest supplier?
  2. Nomad
    Nomad Active Member
    As far as I know, flex track is flex track. Go with the cheapest.
  3. mentor63
    mentor63 Member
    Boy, track has gone up! I swear I bought 100 pieces of Atlas code 83 for about $250 just a couple of years ago. But you are correct as I as far I can see today. In fact, several places don't even list a 100-pack as an item. 1stplace hobbies is usually one of my favorite on-line stores for good prices, but they do not list it now. The best place I found this morning is Cherry Creek Hobbies (cchobbies.com) for $368 for 100 pieces of Atlas code 83 which is what I use and, as others have indicated, there is not much difference in brands. I have always had great, fast service and low prices from them, but if you can get it for $2.60 per section that would be a lot better. Good luck!
  4. Jers2709
    Jers2709 New Member
    I would go with Atlas, they have the best quality. If you're not in a rush to get the track, check with Walthers. They put Atlas flex track on sale every other month.
  5. slekjr
    slekjr Member
    I put a question up here about 6 months ago about the difference between Atlas and Model Power Flex track. The general consensus was there was very little difference. I'm talking code 100 here but the model power is on sale at train world for less than $180 (I think it was $159 but I loaned my latest model railroader magazine.) They also have the Atlas in code 83 and 100 cheaper then anywhere else I have found.
    One LHS here is selling Atlas code 100 for $9.95 ea. (a true bargain)
  6. cidchase
    cidchase Active Member
    Hi Kent,
    I've only used the Model power in N-scale and I remember I did not like working with it much.
    For Atlas, try: Atlas HO Track and Accessories - Trainworld 718-436-7072
    US 28.00 for 10 pcs.
    Used them in the past, they were very professional, well stocked, shipped quick. I'm surprised at cchobbies, I thought they were often low also. Let us know how it turns out!! Good Luck!
  7. KentBy
    KentBy GN, NP, SP&S
    Wow, best price I have seen.
    The 100 piece price is 209.99.:wave:
  8. EvoMan454
    EvoMan454 New Member
    While the topic is up I have 2 questions. 1: When ordering from cchobbies.com can you order online and on the phone? And I know this is a little off topic but will the Atlas switch machines (regular, not under table) work with #6 switches? Thanks
  9. mentor63
    mentor63 Member
    I know you can order from cchobbies by phone since I have done that. I believe you can order via the email address they provide also. Sorry, can't help with the Atlas switch machine as I have not used them.
  10. phoneguy
    phoneguy member
    Yes the atlas switch machines work with #6 switches
  11. EvoMan454
    Ok thanks guys.
