Hope you get a "lift" out of this...
Discussion in 'Photos & Videos' started by doctorwayne, Nov 16, 2005.
  1. doctorwayne
    doctorwayne Active Member
    short train carrying some parts for a large overhead crane. The locomotive, an Athearn SW1200, modified into an NW-2, is lettered for the Grand River Southern, a terminal company held jointly by the EG&E and the GVC. It's equipped with a can motor and has been re-geared. Pick-up shoes on both trucks make it almost unstallable.
    The first car, an empty gondola, is a modified Concor, followed by a GSC flatcar by Walthers. The load represents one end assembly of the bridge of a large overhead crane.
    This gondola, from Proto2000, is carrying one of the crane's two main bridge members. They will be assembled, on-site, with the loads from the first and last cars in the train to form the bridge assembly.
    This is another GSC flatcar: the load represents the main side members of the trolley which will run on top of the bridge.
    Here's the other bridge member, in another Proto2000 gondola.
    The next shot shows the other bridge end on another flat, followed by another Concor gondola.
    And finally, the caboose.
    All of the freight cars have been modified with wire grabirons and A-Line steps. The crane parts are built-up from sheet and strip styrene. The "wood" blocking is also styrene strip. All of the loads are removeable. The train originated at Dominion Bridge, a factory not modelled, but rather represented, along with several other industries, by two long industrial "staging sidings" located under the Grand Valley's main south end staging yard.
  2. Gary Pfeil
    Gary Pfeil Active Member
    Wayne, I never get tired of seeing your work! In addition to the nice work on the loco and rolling stock, I really like your structures. The background bldg. which looks to be built on a curve in particular grabs the eye. Cool stuff!
  3. TomPM
    TomPM Another Fried Egg Fan
    Awesome looking train!
  4. doctorwayne
    Thanks for the appreciative remarks. You're right Gary, in the first two shots, the building on the extreme right, National Grocers, is curved. It's connected, via overhead passageways, to the building where the reefer is spotted in the first picture. The rear wall of this building is curved also. Between the two structures, on the elevated grade separation seen in some of my other posts, is the double track main line of the GVC. The train in the photo is on the former main, now just an industrial connecting line. It curves around the tall part of the building behind the loco, then ducks between this building and the shorter brick structure visible, in the first shot, just over the hood of the loco, then disappears through a hole in the backdrop. The entire National Grocers complex was designed to de-emphasize the inordinately high grade separation and to hide the entry of both the low and high lines through the backdrop to staging. Design Preservation modular walls, in two styles, were used for the extemely odd shaped buildings: roofs and the unseen back walls are .060" styrene. The low building seen over the loco's hood is leftover parts from the P&M Languay complex, seen in another post. This building, named for a real industry, is the Evel Casket Company, so Tyco's version wasn't all that fanciful.
    One final remark. Looking at these pictures, I notice that there's quite a colour shift from the actual scene, probably due to the fluorescent lights used in the layout room. The loco is actually in a modified version of CNR's green and yellow paint scheme (same colours, different layout), and the crane load featured is in Floquil Reefer Orange, unweathered, obviously.
  5. nachoman
    nachoman Guest
    sheesh, that's awesome!!
  6. Ralph
    Interesting subject and beautiful photos of a very nice looking layout!
  7. Tyson Rayles
    Tyson Rayles Active Member
    Very nice work! Think you could shrink the pics a little though? It's nicer when you can see the whole pic without having to scroll up, down, left and right. It also would be a lot easier for those on dail-up.
  8. Drew1125
    Drew1125 Active Member
    Once again, beautiful modeling & photos, Wayne!
    :thumb: :cool: :cool: :thumb:
  9. 60103
    Dr. W.: interesting work. Will the crane be installed at the end of the run?
    Interesting to see National Grocers. My grandfather used to manage their Niagara Falls office. It was situated on a curved spur at the top of Clifton Hill.
  10. Ray Marinaccio
    Ray Marinaccio Active Member
    Excellent modeling and photos Wayne. :thumb:
    The load brings back memories.
    At the trucking company I worked for I designed and built steerable trailers to haul such loads over the road.
  11. doctorwayne
    Once again, thanks to everyone for the compliments.
    I have tried to shrink the picture size, but so far, no luck. I store the photos at Photobucket: I just download them from a CD, but for some reason, the pictures are different sizes. I have some that are about 300x400 85k, and others that are 800x600 120k. Photobucket allows you to re-size the pictures smaller, so I shrank one of the large ones down to 200x150 19k, then did a test post here of the original and the smaller version. Both showed up as the same size. Large! ezdays recommended PhotoPlus, so I downloaded it but it seems to me to be overwhelming. Computers, the language, the logic of it, make almost no sense to me. It's like trying to write a great novel with the pen held in your toes: by the time I can form a word, I've lost the thought. Whatever I manage to post here, whether pictures or words, ends up taking way longer than it should, and of course, it doesn't help that I'm so wordy. I do understand the desireability of shrinking the photos, so I'll try to get my elusive daughter to help me out.
  12. Iron Goat
    Iron Goat Member
    Fantastic modeling and photography, Wayne......
  13. zedob
    zedob Member
    Soooo, cooool.
  14. CSX
    CSX Member
    All I can say is WOW, nicely done!
  15. RailRon
    RailRon Active Member
    Wayne, your modeling is absolute top notch! :thumb: :thumb: :thumb:
    You have chosen a very interesting object. And the way the heavy load is handled is absolutely prototypic. Did you model that crane after an existing prototype, or did you 'imagineere' it?
  16. Clerk
    Clerk Active Member
    Wayne. I couldn't tell if those were pictures of the real thing or a model. Anyway, nice pictures
  17. doctorwayne
    I was just checking through some of my past posts to see if the pictures were still showing up and I came across Ron's question, which I hadn't noticed previously. The crane was inspired by the cranes I saw in the steel mill where I worked. There were 11 of them in our mill, ranging from a 15 tonner up to a hundred tonner, although most of them had a greater span than the one featured here. I vaguely remember watching them put up a crane in a new building right beside the mill where I worked: it was a 600 tonner.
    Anyway, Ron, sorry for the delay in my response.
  18. Chessie6459
    Chessie6459 Gauge Oldtimer
    Great Pictures Wayne.:thumb: :thumb: :thumb: :thumb:
  19. RailRon
    No problem, Wayne - thank you for answering. :wave:
    Again: Outstanding modeling and photography! :thumb:
  20. lester perry
    lester perry Active Member
    I have no problem with the pic size and I am dial up. They fit perfectly on my screen. The only problem I have is I am going to quit. You make me look like an amature, which I guess I am. But anyway FANTASTIC modeling & photography.
