Double Crossover issues
Discussion in 'HO Scale Model Trains' started by SteveInBama, Jan 28, 2008.
  1. SteveInBama
    SteveInBama New Member
    Thanks all ,
    Located a Shinohara HO ~$45 ( apparently like Santa Fe Jack above). It is about 20" long but HO Code 83 - not sure what I will need to do if anyting with Atlas Code 100 ? Also if remote DCC/Digitrax will work with a snap remote?
    Comments anyone?
  2. steamhead
    steamhead Active Member
    Lucky to have found it..!! I understand there are special railjoiners that'll lift your code 83 to the height of the 100. I would presume you'd need to shim the code 83 turnout so it won't sag in the center.
    Good luck..!!
  3. 60103
    Steve: I haven't worked with code 83, but I do have 100 and 75 on my layout. If you can't find the special joiners, you may be able to make a transition from code 100 joiners. I put them onto the code 100 rail and flatten the outer half with pliers. Then solder the smaller rail onto the flat section so it's level with the other rail (and lines up on the inside edge). Test that it's flattened and low enough before soldering. You might want to use a small section of plain track for this rather than soldering to your expensive double crossover. There's no telling about shimming the track afterwards as there are no standards for tie height.
  4. SteveInBama
    Thanks David, By "low enough" I think you mean even/smooth at the top of the rail where the two types meet? (after mod/crimp of the rail joiners)
    Sounds like this combo of code 83 with code 100 track will be considerable trial and error.
    Thanks for the guidelines.
  5. 60103
    Steve: even with Peco's code 75 and code 100, one track needs shimming. I found two sheets of very thin card worked -- one of them twice as long as the other.
    And I have pictures of prototype rail joiners joining 2 sizes of rail. CN has a siding where the mainline has 4-bolt fishplates and the siding has 6 bolt fishplates on smaller rail; the transition has 5-bolt fishplates!
  6. mentor63
    mentor63 Member
    I was just surfing the net for a turnout and came across an Altas listing. They make transition joiners for code 100 to 83 if that helps. They under $3 for 12 joiners
  7. SteveInBama
    Thanks all, I just hated to start "new" with a crossover I had to modify.
  8. cidchase
    cidchase Active Member
    Hi Steve,
    Just out of curiosity, what is the track centerline spacing on your Shinohara?
  9. SteveInBama
    The distiance, center line to center line is 2 inches. I ordered the double crossover - in stock - from The Engine Tender as Shinohara track part number 669 - 112, - description " cd 100 #6 dbl crossover ". It will be a while before I attempt to have it working....
  10. DRail
    DRail New Member
    Hi all! I'm interested in the Walthers/Shinohara code 83 crossover (part number 948-8812 in the Walthers catalogue). I'd really like to know the centerline spacing. It doesn't seem to be mentioned anywhere. Is it the same 2 inches as for the Code 100 Shinohara one that Steve told about?
    Thanks in advance,
  11. mentor63
    mentor63 Member
    As far as I can tell the Walthers catalog does not give that measurement, but I measured mine and they appear to be 2" centerline spacing as close as I could measure it. Hope that helps, Gary
  12. DRail
    DRail New Member
    @Gary: thanks a lot!
