Designing Cardmodels - Paragon Style
Discussion in 'Tutorials' started by Paragon, Dec 14, 2007.
  1. JT Fox
    JT Fox Member
    Hi Paragon, great design style.
    I'm current working on a design using Metasequoia / pepakura following a tutorial elsewhere in the forum.
    Your system looks so much simpler on paper, (sorry, poor joke), I though I'd do your style in parallel and see which method give the best time taken by model quality result.
    One question. When you place you top/side/bottom views together how do you work out the overlap? To much overlap and the body would be skinny, not enough and it would be fat. Is there some sort of number crunching or do you use your best judgment?
    Cheers JTF
  2. Paragon
    Paragon Active Member
    Mostly best judgement. Typically, there are details from the side view that are also in the top and bottom views, and that marks the appropriate amount of overlap, just lay those details atop each other. Its not always perfect, of course, so the best defence against that problem is testbuilding! Since my models are very simply, testbuilds don't take up much time or paper, for other models, this might not be the case.
    I do also have to warn that I believe model quality drops when using this method. It is not as accurate when designing this way unless you test different parts over and over until they're perfect. I'm not sure how much more time this would take.
  3. JT Fox
    JT Fox Member
    Best Judgment it is then.
    Cheers JTF
  4. edi
    edi Member
    Well, I`ve managed to finish my first design, based on Paragons tutorial.
    Okay, there are some mistakes, but all in all I`m quite happy with it.
    The Reggiane is built in 1/144 as usual
  5. Paragon
    Very nice! Do you plan on releasing it?
  6. Paragon
    Oh, btw, mods, any chance of moving this to the Tutorial section? It looks like it belongs there.
  7. edi
    edi Member
    it`s already done
  8. jaffro
    jaffro Long term member
    Done... with a permanent redirect from the original location... better late than never. :D
  9. Arjun
    Arjun Member
    I've been looking at the Swing Wing section of the Instructions page. I have a MiG-23 (or MiG-27) in mind, and I'd like to know how to get the right shape for the inner (gear) parts.
  10. Lex
    Lex Dollmaker
    ...Trial and error I suppose?... :D
  11. Paragon
    It was part trial and error, but I also did a lot of measuring out of circles. Find the focal point on which the wing will pivot, then create a circle that will overlap the same circle on the other wing. Make sure the center is anchored around the wing's focal point, of course. Then draw a second smaller circle inside the first, but it should end where at the edge of the other wing's large circle. The large circle represents the tip of each tooth in the cog, and the smaller circle is the trough between each tooth. Draw one tooth, then duplicate as many times as necessary, and put them around the rest of the cog. Make sure, of course, to offset the opposite wing by one tooth, otherwise the wings will end up at different angles.
  12. rocketmonkey
    rocketmonkey New Member
    Wicked tutorial, Paragon. Nice one mate!
