dcc systems
Discussion in 'Getting Started' started by railroader9731, Jan 30, 2008.
  1. what is every ones dcc system and how dependable is it as its time for me to retire the atlas one i have.
  2. nolatron
    nolatron Member
    Been using Digitrax products (super chief and zephyr) and never had any problems. Never had any problems with either one.
  3. TrainNut
    TrainNut Ditat Deus
    Digitrax Zephyr command station linked to a UR91 and a DT400R remote handheld controller. The Zephyr was always a little finicky. Finally, I had a reverse loop modulator that refused to work as it should. After narrowing down the problem to the command station, I sent it back and they replaced the mother board. Now it works as it should.
  4. Nomad
    Nomad Active Member
    Nce Powercab. No problems at all.
  5. MasonJar
    Digitrax Zephyr plus UT-4R (used tethered) for home. www.hotrak.ca modular club uses a mix of Digitrax - Super Chiefs and Empire Builders, plus just about every other accessory you can think of. Very few problems, considering the size of the set-up. ;) :D
  6. lester perry
    lester perry Active Member
    OK I will be the odball, I have MRCadvance. I love it no problems I have had it for over a year. the reason I got it was I felt it was the most user friendly. I have run with digitrax on a friends layout and felt intimidated by it.
  7. rogerw
    rogerw Active Member
    Easy dcc by cvp. They have the most years/experience in dcc. Totally expandable cheap to start. What I did when it was time for me to select what system to by , I went to all of the forums for each system and asked questions. Just my 4 cents(inflation you know) Do not confuse this easy system with bachmann ez system. Totally different animal.
    Edit: just read the article in March Model railroader page 86. They did a review on the CVP wireless system:thumb::thumb:. Did not know Kahlmbach publishing used this system on there huge layout.
  8. Kevinkrey
    Kevinkrey Member
    Does anybody know if a Bachman EZ command booster will work with other systems, more specifically, NCE powercab, or where the best place to buy a NCE powercab is?​
  9. MadHatter
    MadHatter Charging at full tilt.
    These days everything is made to NMRA standard, so the Bachmann should work, otherwise it won't sell.
  10. MasonJar
    I don't know if the Bachmann unit will work with the NCE system. The NMRA standards only ensure that all decoders work with all systems, but not necessarily that components of different systems work together.
  11. tetters
    tetters Rail Spiking Fool!
    Ditto. Great starter system as far as I can tell. If I do have a small gripe is the thumbwheel in the center. I'm just being picky though as it was super easy to set up and start programming locos right away.
    I would eventually like to get my hands on the CAB04p Engineer Cab with potentiometer to use a throttle instead of using the Power Cab itself. Then I would just use the PC itself for programming et al.
  12. DeckRoid
    DeckRoid Member
    I got the Zephyr for xmas after they dropped the prices. Works great. My only issue is that I can't program my decoders with sound. The controller tells me there is not enough power to the track. But for my non-sound decoders, it programs like it should.
    When I was wiring my track, I put a power drop every 6 feet. There is no slow downs, no flickering of lights... just smooth running trains. I love it.
    ** Edit ** I have different decoders in my trains, and they all work. MRC, Bachmann and a couple generic ones from the LHS.
  13. Kevinkrey
    Kevinkrey Member
    I have 9x20 layout appx. with a 8' long double track extension. I want something that will work as is, without needing to buy more. What would be a good system without spending more than $200? I want something that has mainline programming, and can be expanded somewhat, MAYBE an additional controller, and something that could maybe be put to use on a future layout. What do you all think?
  14. lester perry
    Under $200 as far as I know that is not availible unless you go with used but I still say MRC Prodigy advance is best buy out there it will do all you are asking for and I think it is most economical one. I am not for sure but I believe it is going for a little less thn $400 you can go wireless later or to start for more $$
  15. KentBy
    KentBy GN, NP, SP&S
    I have been trying to figure out what to buy also.
    My layout will be 17x14 and I would like two controls eventually. I think that I would only run 3 to 4 trains at a time, but one or two could be double header. And then what if I add sound. How many amps do I need? 3, 5?
    Would the Prodigy Advance work for this?
    I won't need all this capability for a year or two as I am just starting on the layout now. But I don't want to buy something that gets discarded latter so that I can upgrade.
  16. rogerw
    Questions , does the prodigy have computer interface or wireless capability ?
  17. Harold Cole
    Harold Cole Member
    You are of several people that have said Digitrax is intimidating to them,what is so intimidating┬┐
  18. rogerw
    What ever system you go with I would make sure it has a computer interface. There is free software that will let you program your decoders CV's on the computer screen then download to the decoder. Much easier than trying to load with the command station. May not be a big deal with one or two locos but when the roster gets bigger it will help. If you have to reset a decoder and clear it out, Its just a matter of reprogramming the settings you saved on the computer.
  19. steamhead
    steamhead Active Member
    Of course, I can't offer an opinion on other systems, but I have used the Zephyr for over 4 years now and it is really great. Just read the instructions, and take your time...It is quite user-friendly and does just about anything you might need at this time. It can be expanded as your needs increase, and incorporated into the "higher end" D'trax components.
  20. brakie
    brakie Active Member
    I have used Digitrax so,when the club voted in DCC we decided on Digitrax..Of course there was some prodding to go Digitrax by some of us.
    I really like the UT2 and the UT4 throttle.:thumb:
