Hi, All!
What better way to start off the new year but with a new model?:grin:
I figured I would try something new with something new, so I reduced this kit to a Micromodel scale...it is a Wilhelmshaven model from the Lehrmittelinstitut series originally in 1:500 scale (this one of the KREFELD is a motor ship freighter, kit number 502), which I scanned and then printed out at 50% to give me a 1:1000 scale ship model. At this scale, as I am learning, the paper thickness has to be considered as it affects to some degree the way the parts fit together, but more on that later.
One thing I like about this series is the way the models is the way the formers are made so as to guide the decks into place using slots, and in the larger scale there are slots cut into the deck to help in placement of the bulkheads which have tabs, but I felt it's easier to assemble to remove all tabs, so the slots in the decks were not used in construction...the formers, however, still helped if placing the decks.
Here's the hull constructed in which you can see the way the formers rise and help in placing the main deck.
Here's another view:
One thing I would do different next time is to detach the hull sides from the base part; as originally designed the sides fold up at the center area, and are glued with tabs at the bow and stern. I felt the paper thickness at this scale imparted a bit of a gap at the fold which I thought, although small, is noticeable and doesn't allow a smooth run of the joint between the sides and base.
Cheers!
Jim
(continued)
Cheers!
Jim
(continued)
