Good technique - but before leaping into this some research is needed. Generally all tank hulls before WW2 were riveted plate on frames - the seams were the plate joins. During WW2 both welded and cast hulls and turrets were used. Casting often leaves prominent seam lines which shouldn't be confused with weld beads.
Regards
Charlie
Regards
Charlie
