Scale question
12,450
That depends on the size of the man / woman / tree. An average human of about 175 cm would be 1750 mm / 400 = 4.375 mm tall. :)
SCEtoAux
175
22
18
USA
A 20 meter tall tree would be 5 cm at 1/400 scale.
Figure 2.5 cm for every 10 meters in height.
micahrogers
3,786
4,652
Shannon GA
One reason I like Metric.... it scales readily.... except 1/48th scale.... which used to be known as "Quarter Inch Scale"... because 1 foot at 1/48th equals 1/4 inch.
9,594
What I don't like about metric is when you actually have to build something. Between number, Letter, and Fractional drills, the increments are in .0001"s 10th's of a thousandths of a inch. There are so many more thread sizes, you will never find machine size threads in metric, as in hi-tech sewing machines, which is why American SAE will never gone. Metric has been absorbed and any machinist or mechanic worth his salt has tooling for both, but what you can do in SAE you cannot do in Metric. It is easier though, and for certain applications, it may be better, such as space travel, and similarly related measurements.
Yes, metric scales up easier, when making these models though, biological objects will never be the same size, so both systems go out the window. You have to design on a "mean", and decide how much you will vary from it.
12,450
@Tonino , I almost forgot about that! This is a very handy tool and it is awesome to see it as a "standalone feature" (it works without having to go through an installer or such; it is sleek and efficient). If you hadn't uploaded it I would have done it. Excellent work and thank you for making it! :)
Reactions: Tonino
