Having a run at the Legal01 Re-envisioned Saturn V Mark III
SonOfAGun2501
Esteemed Member Extroadinaire
May 11, 2014
324
642
83
45
Ichikawadaimon, Japan
Having no experience with this model I still have a question: Have you, or any other builder, ever considered to superdetail the outside at the places where the real thing has those ribbed areas. such as on the lower stage, winged engine covers and interstage?
A hell-of-a-job but almost a must-go-there in this scale, I think.
This is a model that is truly massive. Detailing the outside becomes fairly easy at this scale. There is more I would like to do with it detail wise, but this is still in test build phase as far as I know. The master mind who combined all the different models together and re-detailed this to make it all similar was, Legal01. In the future though, I would like to try this in a smaller scale. If you are familiar with scratch building your own parts, there is a lot you could do to this model detail wise.
SonOfAGun2501
May 11, 2014
324
642
83
45
Details are slowly being added to the master files, its a massive job and really only for the serious enthusiast to make every rib and detail that this design has.
All that you have done so far is incredible. Pieces are coming together nicely. It's good to hear from you again Legal, I hope you have been well.
9,991
I am one of those serious (CRAZY :hammerhead::hammerhead::hammerhead:) enthusiasts that would sit there and make every rib and greeble that you put into it!!!thumbsupthumbsupthumbsup
9,593
I hope people are clicking on the thumbnails to see the expertise in the building going on here, it is perfection!! Click on this pic to see what I mean. ;)
20160504_104416-jpg.150586
SonOfAGun2501
May 11, 2014
324
642
83
45
Once again on mounting the top and bottom of the bell if you want to make the connection seamless you would just need to cut parts 11 a bit shorter.
20160504_154621.jpg 20160504_154630.jpgWith part 20 just make sure everything is aligned correctly and it should more or less place itself. There is a white mark on part 14 that will help with the alignment.
20160504_162653.jpg 20160504_162701.jpg 20160504_162710.jpg 20160504_162715.jpg
Parts 24,25,26,27 assembly will be the same for parts 28,29,30,31 so I only showed the one assembly.
20160504_164439.jpg 20160504_173027.jpg 20160504_173734.jpg 20160504_174740.jpg
Be sure to keep track of which parts are which the next step can be confusing if you aren't paying attention.
SonOfAGun2501
May 11, 2014
324
642
83
45
For parts 32,33 if you use a 1mm dowel in the center that works out really well for the correct sizing.
Parts 37 and 38 just need to be folded and laminated together. When placing on the engine it helps if you pre-curl the back ends also, in my pics I initially folded the tabs at the bottom backwards.
20160505_104909.jpg 20160505_105522.jpg 20160505_110904.jpg 20160505_111042.jpg 20160505_111808.jpg 20160505_111817.jpg
SonOfAGun2501
May 11, 2014
324
642
83
45
Parts 53 and 54 were a bit of a pain to figure out. However this is more or less what it is supposed to look like sadly, I put mine on backwards the rest of the engines will be done correctly.
20160505_151459.jpg 20160505_151509.jpg 20160505_151519.jpg 20160505_174426.jpg 20160505_175651.jpg 20160505_175827.jpg
And these are the last two bits to attach and here we have more or less a finished J2 engine. I do need to get a bead to finish it off. Will add more pics when I do. Time to build the other 5.
Reactions: Rhaven Blaack
