Has anyone used carbon powder to make trace lines for adding lighting elements
Jadriancz
127
Colorado
We have all seen those electrical conductive paints (50 ml for $20 and up.).
Well I was thinking this could be made easily and much cheaper since carbon is a conductive material.
You can purchase activated carbon pellets (40 oz bottle for about $10 US) from pet stores which are used in filters for fish tanks.
Using a spice grinder to turn it into fine powder. (You now have 1182 ml for $10)
(Make sure to do this in a well ventilated area using filter masks as the dust is toxic and flammable).
Mix with glue and paint the lines on the interior side to the lighting locations on the model and attach the leds and battery wiring.
The glue helps bind it into the paper fibers.
Could also use caulking for flexibility as needed.
Reactions: lyter1958
ennder
459
1,111
83
I used graphite powder from pencil lead for weathering, back when I built plastic models.
spaceagent-9
Right Hand Man and Confidant
3,119
3,484
143
pheonix
they even have conductive colored ink pens, something like a silver laundry marker, there are videos on youtube.
Jadriancz
127
Colorado
You’d have to be careful with the voltage. Too much would produce heat and a pile of ash that used to be your model.
Possibly, but I dont think most led wiring setups for paper models would exceed its capabilites or come close to it. I am not an electrical engineer myself so not sure.
9,593
Get your Ohm meter out and measure the conductivity. It's all Ohm's law from there on out. LED's need very little forward Voltage to turn them on, and very little current, depending on how bright they are. Automotive Headlight LED's use a lot of amps. :)
Gandolf50
1,327
1,576
96
New Mexico USA
You can get copper tape used for stained glass work, and tap into it as needed. There is also fabric wire which you can weave into shirts and clothing and add the LED's ( it is actually transductant wire or something like that)... There are lots of ways to get a model lit up without grinding carbon!
Reactions: Cybergrinder
9,593
I have noticed that people are using wires that are far too fat for these LED's. One wire you may want to consider is wire sold to wrap coils (Magnet Wire). The wire is coated, so it doesn't conduct, but are almost hairlike, allowing really easy removal of the insulation, which is usually clear, or translucent colored, soldering, and running the whole collection of wires into a harness without worrying about short circuits. Twisted pairs could be used to carry more current, but your wiring options become much more concealed, even allowing for socket to be made so you plug your LED's in, instead of soldering them. :)
https://www.amazon.com/Metal-Alloy-Magnet-Wire/b?ie=UTF8&node=310354011
