Firefly - Serenity
9,593
A baby that has bugs is neglected. Must be something lost in the translation. I'd play with that ship too, lots of places to land it!! ;)
Baby Bugs Bunny:
Reactions: Sky Seeker
Sky Seeker
Well Established Member
Jun 1, 2015
1,178
1,083
95
More pics - nearing final assembly!
As you can see there is a bit of a gap on the side between the fuselage and the cabin and the cargo bay during test fitting.
A strip from a reprint of the cradle is being used to fill in the gap (see below).
Fuselage, cabin and cargo bays assembled together (this was REALLY tough!)
Right side - note the area where the strip was applied - is there a gap? What gap?!?;)
Left side - this area had a gap however the same technique that was used before on the other side was used on this one. What do you think?
Front view - cargo bay - a silver marker was used to remove some extra dark areas. Do you see where I did the coloring?
Front view.
Getting some of the solar panels ready - note the edges have been colored. Also, when you fold the pieces over each other make sure they line up. Also, be sure to color the backs as well.
That's it for now.
Sky Seeker
:tank:
Sky Seeker
Jun 1, 2015
1,178
1,083
95
Mostly done - major pieces assembled. All that's left do do now is some minor details and adding the solar panels. Maybe a stand, but I'll see how much time I've got as I'll be traveling to the Bermuda Triangle soon!
Front view
Right front view.
Left front view.
Left side view
Left rear view.
Rear View.
Right rear view.
Right side.
Top view.
Front view with shuttles - wings open.
Front view with shuttles - wings closed.
Bottom view.
Bottom view.
Top view.
That's it for now. Definitely on the "home stretch"!:)
Sky Seeker
:tank:
12,445
FANTASTIC!!! :Bravo::Bravo::Bravo:
Your fixes are almost invisible and look like they are part of the original design. I hope you are planning to get out of the Triangle again, right?;)
Sky Seeker
Jun 1, 2015
1,178
1,083
95
Unfortunately Yes. ;) I could take a few years off though that would be fine with me!:) Looking forward to the beaches and the "big blue" of the Atlantic Ocean.
Sky Seeker
:tank:
9,593
Bravo, fantastic job. Another excellent build thread to top it off!! What a beauty!! :)
Sky Seeker
Jun 1, 2015
1,178
1,083
95
Thanks Z!:) Still have to put on the solar panels and the antennas for around the cockpit area. Hopefully:angelic:, it will be done by this weekend.:)
Sky Seeker
:tank:
Sky Seeker
Jun 1, 2015
1,178
1,083
95
Final pics (at least for this version of Serenity)
Solar Panels - There's no precise positioning for the solar panels - i.e. no plans in the templates. This is about as good a guess as I've got on where to put these. Recommend research on your own before you place these.
Left Side view
Left Front view - note that the solar panel was aligned with the line right next to the Serenity logo.
Right Front view
Right Front view
Right Side view - note the solar panel on the cargo bay
Left Front view - Note the position of the solar panels and the cargo bay.
Left Front view.
Right Front view.
Overall this model was a bit difficult at times to build. This is definitely NOT for a novice builder. Here are some suggestions on areas to pay attention to when building (and maybe some improvements for future builds):
Fuselage - cockpit could use an addition of an actual cockpit inside and antennas on the crown section near the cockpit.
Fuselage is pretty tough to attach to the cargo bay and to the cabin (turtle section). Be careful of the gaps between the cabin section, cargo bay, and the fuselage.
Cabin area (turtle section) could use some transparent windows to look inside the dining area and the med bay.
Engines on the side - orange engine flares could be added to the exhaust ports of the engine.
Wings - be careful of the clearance issues on the side of the cargo bay.:frak: Be sure to add tabs and maybe an internal spar for the wings. Perhaps a spar could be added that permits vertical tilting of the engines.
Engine cradle - be careful of of misalignment early on in assembly:headbange:, start on either side of the center and glue before the gluing of the top center of the cradle. Legs of the cradle form a natural twist. Just go with it.
Engine - better construction of the pipes could be done. It would be nice to have templates for the pipes. More greebling could be done on the engine to enhance details. More experimentation with flap openings along the back of the main engine for "full thrust" effect. LEDs should be added particularly for the main engine.
Shuttle - A redesign for the shuttle is DEFINITELY possible. The foldable wings were NOT stock and should be included in any build. Don't know why they weren't included in the first place.
Research for the Serenity is DEFINITELY a MUST!!! :animated:
(OK it's just a good excuse to watch the series and movie again and again!:))
Here's the title song for the series.
The lyrics for the ballad of Serenity - sung by Sonny Rhodes.
Take my love, take my land
Take me where I cannot stand
I don't care cause I'm still free
You can't take the sky from me
Take me out, to the black
Tell 'em I ain't coming back
Burn the land and boil the sea
There's no place I can be
Since I found serenity
I don't care, I'm still free
Hope you've enjoyed this thread as much as I've had in making the Serenity.
In case you're wondering - this particular model was built for a friend of mine and his bride. Both BIG Serenity fans!
One of these days I'll build my own.
Take care and keep on geeblin'.:)
Sky Seeker
:tank:
