basic binding of a pdf printed book
lons fede
hello this is not papercraft but it has a bit to do with it. This year I started to chain my books that I printed on A5 sheet with my printer. Before, I printed them and sent them to be ringed.
This was done years ago with my grandfather (he bound and I saw) he was a lover of books, things that I and my brother inherited. After his death, I did not bind again until this year.
Here in Argentina, new books or those that are difficult to obtain are expensive, I am content with printing them and ringing them. This year I started binding out of nostalgia and because I wanted to give color to my library, and thus not see only ringed spines with nothing to say which book is which.
Notice that it is only a basic loose-leaf binding with a hard cover and very cheap materials.
The book in question that I present for this binding is "three dwarfs and a peak" by angel sanchidrian. I highly recommend that you read it, you will laugh on every page as it destroys every cliché of fantasy.
It is a book that I read on the computer a year after it came out and it is one of my favorite fantasy books.
I couldn't buy this book in any of its printed formats and I didn't use it either because it's very expensive and that's why I decided to print it on A5 sheets and bind it, this isn't the first book I've bound, but it's the one I'm showing you here.
This new or used book in Argentina today has a price of 7,000 to 12,000 Argentine pesos and with my imperfection and binding I don't spend more than 1,000 pesos.
well without further introductions I present a basic binding of loose sheets in A5
WhatsApp Image 2023-07-27 at 12.16.52.jpegWhatsApp Image 2023-07-27 at 12.16.52 (1).jpeg
As I said, print the PDF book on an A5 sheet and in all the photos I will censor the page from which I downloaded
WhatsApp Image 2023-07-27 at 12.16.53.jpegWhatsApp Image 2023-07-27 at 12.16.54.jpeg
Once printed, I aligned it as best I could and I put it in the homemade press that I made when I started with this. It is necessary that it be aligned correctly, especially on the slime, and then glue it with white plastic glue
WhatsApp Image 2023-07-27 at 12.16.54 (1).jpegWhatsApp Image 2023-07-27 at 12.16.54 (2).jpeg
WhatsApp Image 2023-07-27 at 12.16.55.jpegWhatsApp Image 2023-07-27 at 12.16.55 (1).jpeg
Between layer and layer of glue, let it dry for 20 minutes and in total I made 5 layers with the white plastic. He noted that the first two layers were diluted to 10% with water for better penetration and the last two I put pure.
WhatsApp Image 2023-07-27 at 12.16.55 (3).jpegWhatsApp Image 2023-07-27 at 12.16.56 (1).jpeg
Once the glue has dried, the cut marks are made starting from the edges at 1 cm, from that it is marked in half and then divided in two and we proceed to cut with a saw two millimeters deep in each cut
then with some cotton or waxed thread we count four sections of the length of the book
WhatsApp Image 2023-07-27 at 12.16.56 (2).jpegWhatsApp Image 2023-07-27 at 12.16.56 (4).jpeg
more glue is put between the slots of the cut and the sewing is done by dividing the thread in two and the middle is placed in the first slot, then a simple knot is made and before closing it, it is placed in the next slot and stretched the thread to close the knot inside the groove. so until you have all the slots
They should look more or less like the last photos. Tomorrow when I cut the covers and buy more glue (haha I ran out and I didn't realize hahahaha) I finished the book binding.
I hope you like this publication and its continuation
lons fede
hello today continue with this bookbinding at low monetary cost.
as I already showed before. once the simple sewing of the sheets is done.
I would continue to do the back covers. I make these with the same paper which I fold in two and glue in the way I show in the images.
in this way I can glue the book covers and pages together
WhatsApp Image 2023-07-27 at 12.16.57.jpegWhatsApp Image 2023-07-27 at 12.16.57 (1).jpeg
WhatsApp Image 2023-07-27 at 12.16.58.jpegWhatsApp Image 2023-07-27 at 12.16.58 (1).jpeg
After this I begin to assemble what will be the cover of the book. I hope you like it.
I see you later
lons fede
continuing today with the work of the book.
I start with the pressing or gray cardboard covers.
These should be 1cm taller than the length of the book and just as wide as the book itself.(This is to leave a 0.5 cm margin around the periphery, once the work is done you will understand it better)
the spine must be the same height as the covers and its width is the sum of the thickness of the book and the thickness of the covers together.
See the image for more references.
WhatsApp Image 2023-08-01 at 19.38.37.jpegWhatsApp Image 2023-08-01 at 19.39.01.jpeg
then we continue with what would be the cover of the book.
This is 200 gr gray cardboard, which we only need half of.
use 200 gram cardstock because it is a good cheap substitute for binding cloth.
We make a centered line by placing the spine cardboard in the center of the cardboard and measuring so that it is at the same distance from the edges.
I stay 21 cm on each side and high measures 4.5 cm on each side. look at the picture
then we wet one side of the spine with water and a brush and we applied plasticola to the cardboard in the area where it was going to be glued.
We place the wet face on the area with glue and press hard. Then we turn the whole over and with a heavy and low-friction object we go over the cardboard part to remove the air and make it smooth and well glued.
In my case I used a stapler, the smoothest part (brown part) as shown in the photo
remember to review well to get the air out until you see that no bubbles are formed, I rub for about 20 seconds until this happens.
This time depends on how dry the glue is before doing the process. The drier the faster it becomes.
WhatsApp Image 2023-08-01 at 19.46.00.jpegWhatsApp Image 2023-08-01 at 19.47.44.jpeg
once the spine was glued to the cardboard.
Two parallel lines are made 0.8 cm from the cardboard edges to later put the part of the lids. This margin allows
you to open and close the book comfortably.
the covers are aligned and the gluing process that was done with the spine is repeated. What should be done more diligently and quickly so that the final surface is very smooth. this with practice is learned well.
When I started with this on the lid there was always some wrinkle after the process, that's why I tell you practice.
If I were to use binding cloth this won't happen, but since it's a low-cost binding I don't use it here
The photos below show you how the process looks when everything is finished drying and you will see how smooth it is.
WhatsApp Image 2023-08-01 at 19.55.26.jpegWhatsApp Image 2023-08-01 at 20.01.23.jpeg
I leave for today, I hope you like how this work is being done. thank you
