WH40K Marauder Destroyer
Wow! That assembly is great!! :)
Moving on to the turret.
Here are the swivel mounts for the guns and the turret box. I mounted the axles inside of the swivel mounts (for additional strength).
I cut one of the axles (linearly) into strips, so that I can slide one axle into the other for a stronger connection.
I attached the canopy window.
The guns are assembled (with additional greebling).
I attached the guns over the seams of the swivel mounts.
These are the parts for the swivel mount of the turret.
The swivel mount of the gunner station is assembled.
The turret is mounted on the swivel mount.
The spacer for the armour plates are attached.
The armour plates are attached.
The turret is put in place. This section is finished.
With this post, I will show two sections of the fuselage built, and three sections assembled to finish off the fuselage.
This section was very straight forward. I had no problems with it.
The section is attached to the fuselage.
I have finished the main body. I did not have any problems with the last section.
THis section is attached to the rest of the fuselage.
The tail/rear weapons section is attached to the fuselage, finishing out the whole fuselage section.
