Z-scale Question
Discussion in 'N / Z Scale Model Trains' started by Mountain Man, Jun 20, 2008.
  1. Mountain Man
    Mountain Man Active Member
    Here is a totally dumb question: what is the actualy width between rails for Z-scale?
    I tried to find some track to look at in the LHS last week, but none was in stock. My curiousity was aroused by the idea that Z-scale track and ore cars might be small enough to use as mine cars in N-scale...?
    OK - I'm wearing my Kevlar underwear with the Nomex lining. Go ahead...I probably deserve it... :cool:
  2. ScratchyAngel
    ScratchyAngel Member
    I'm guessing it would be 56"/220 = .254" (and x 25.4mm/" = around 6.5mm). This is just from using the scale though, maybe the gauge is not quite that accurate.
  3. rhtastro
    rhtastro Member
    SA is right. Out of the Marklin book, the gauge of Z track is 6.5 mm or one fourth inch, the total width is 11.5 mm or 29/64 inches, the height is 2.5 mm or about 3/32 inches.
    Bob :wave::wave:
  4. Mountain Man
    Hmmm...well, it wasn't a brilliant idea to begin with...:oops:
    Thanks, everyone.
    Misplaced my scale ruler...again...wall1
  5. ScratchyAngel
    Have you considered the stuff from the N Scale Architect?
    Master Craftsman Series
    It's down around the Lackawanna Coal Company.
  6. Mountain Man
    Great link, ScratchyAngel - thank you!
    Interesting screen name, too!
  7. Triplex
    Triplex Active Member
    Z track is between metre and Cape gauge in N scale. The European term Nm is reasonably correct; Nn3 is a misnomer.
  8. Mountain Man
    Funny thing - I actually had an "expert" at the LHS tell me that Z-scale track was 0ne-half N-scale. He was startled when I told him, it couldn't be, as Z-scale is !:220, not nearly small enough to be one-half of N.
    Got to watch those "experts". :rolleyes:
  9. pgandw
    pgandw Active Member
    Nn3 - N scale models of 3ft gauge prototypes - use Z mechanisms, track, and Z gauge of 6.5mm as reasonably close.
    56.5" gauge is 8.97mm in 1/160 N scale, close enough to 9mm, which is where the N designator comes from.
    36" in N scale is 5.72mm. But just like HOn2 uses N gauge and Sn2 uses HOn3 or N, Nn3 uses a commercially available gauge. Actually, Z gauge equals about 22 inches in HO scale, and would be much closer to true HOn2 than N gauge is. But HOn30 has been around for a while, and is usually used for HOn2 models.
  10. Mountain Man
    Yep! But it doesn't help with my problem anyway 'cause it ain't "one-half of N-scale! :cool:
