Well, I sure am glad Global Warming is a Hoax...only pushing over 100 for the next few days...
Gandolf50
1,327
1,576
96
New Mexico USA
Yep, I'm on the edge of the Heat of the Century dome...
My feelings about this???
9,549
No Winters to speak of anymore. Recorded history of weather doesn't go back far enough to come to a conclusion as to what is causing this, but all the Microwaving in the air, the green house gases, and what may be natural occurrences could lead to calamity. I guess some people just don't feel the heat. I'm sweating my &alls off.
snark1950
46
49
Orlando Fl
I tell people I work with if I ever complain its hot in the building call the fire department because the building is burning. Got home from walking two laps around the block soaking wet from the heat and humidity. So its even hot by my standards. oh and my day job involves working with molten solderwork2.png
9,549
My Nephew/Godson shaved his head, and went for a run. He ended getting 2nd degree burns on his head, and shoulders, he wasn';t wearing a shirt. I told him what to rub on his head and shoulders. You can't shave your head too close. I have color in my skin but those U.V. rays are unforgiving. People talk about the heat, but the U.V. rays are destroying a lot of things prematurely, like people who get skin cancer.
mijob
Tie designer
3,187
5,396
95
Netherlands
Last week almost 6 day's in a row we had rain. Yesterday and today at last SUNSHINE!!!!
spaceagent-9
Right Hand Man and Confidant
3,112
3,480
143
62
pheonix
In Arizona here we don't believe in Global Warming, We believe in walking out the door and bursting into flames.
But seriously folks, remember that the heat is pretty bad, but the
dry hot air sucks the water right out of you
and like a car without oil it will mess you up bad with heat stroke-[real strokes] heat exhaustion and just too frickin' hot to do anything, and melt into a bed or chair and nap for 2 hours around 3 pm.
9,549
Funny, next week in Connecticut is going to be the normal type of Connecticut temperatures, high in the high 70's!! Of course, that happened in December too. :)
Gandolf50
1,327
1,576
96
New Mexico USA
Well hang on to your shorts, or rather maybe toss them, as this mega Heat Dome is headed that way...it is supposed to hang around here for a week or so, I guess then slowly get there...considering it reaches from Colorado to Mexico and Arizona to Oklahoma...should not take long!!!
micahrogers
3,773
4,639
Shannon GA
And now solar scientists are saying it looks like the sun is cooling down a bit, and we could actually be headed for a 'Solar Minimum' and the last one of those was in "18 hundred and froze to death".
spaceagent-9
3,112
3,480
143
62
pheonix
wind turbines also! Once your inner core reaches 109' you will start to die, even real strokes will kill areas of your brain. The dehydration factors are so scary that I wont even post them, but remember to drink a 1/2 cup of water ever hour to avoid losing too much moisture, so you wont run around like Dr Smith yelling for moisture in Lost in Space. Signs of dehydration and zombies are very similar- white foam around the mouth, blank stares, disassociation, slow movements. Needing a brain,...? Even at night. I froze a bottle of water and took it with me, it was completely melted in 10 minutes.
9,549
According to our monthly forecast, it seems pretty normal for this time of year. The nights start to cool down around here in August, great motorcycle riding weather. Too hot to ride now, although we had a max of 84 degrees today, but waay too much humidity. :)
spaceagent-9
3,112
3,480
143
62
pheonix
Those of you who are kept hostage by temps rivaling the cauldrons of Hell, might want to air out your homes every morning so that you chill fresh air instead of used air. Here in AZ it can get to be quite a problem, similar to what Apollo 13 faced when they had to build a scrubber out of school supplies.
9,549
Hitting the 90's again next week, ironically, this has been a very normal Connecticut Summer. Unfortunately, we used to have 4 seasons, now we have 2.4, a taste of fall, a taste of Winter, the Spring, which quickly turns into Summer, and snow, well that sometimes actually makes it to the ground, and the countryside looks like a sugar powered forest. I remember snow way over my head. I was only 4 years old at the time, but when I first purchased my present home, we had 6 feet of snow, twice, within two weeks. There was so much snow, with no place to put it, the walls on the road sides were 10 feet high. That has never happened since. Also, the season for riding motorcycles has changed, with the best riding motorcycles coming from August till November. I pulled out my Suzuki yesterday, in anticipation. Night riding at this time is spot on, temperature wise. ;)
12,360
It could be worse:
300 million degrees C - beat that, AZ!
:Grin: :Grin: :Grin:
spaceagent-9
3,112
3,480
143
62
pheonix
Went swimming yesterday, my dome is burnt red, but it sure was nice. Arizona is much like the movie THE ANDROMEDA STRAIN, as you get xenon flashed, baked, have to change your sweaty clothes and then need a gator aid and a nap, every time you come home from being outside.
