Discussion in 'Getting Started' started by nwdyr, Jan 23, 2008.
  1. MasonJar
    Either stick a pin through the hole (and then mark the pinhole later) or just eyeball it on one side of the tie next to the hole. You do need to be reasonably accurate, but not down to the nanometer...! ;)
  2. nwdyr
    nwdyr New Member
    got ya.... thank you!
  3. Biased turkey
    Biased turkey Active Member
    I'm modeling in N scale ( half the size of the HO scale you are modeling ) and to mark the track center I dip a needle in black ink and then insert the needle in the holes locating the track center.
    For the turnouts I build some cardboard templates .
    I know for example that a # 4 Atlas N scale turnout has diverging route with a 19" radius .
  4. 60103
    The holes are for pinning the track down but only if you use something the pin will stick in. They're actually bad news; few real railroads put nailheads in the middle of the ties, and people tend to put a nail though it and wallop it with a hammer to get it down. This creates a depression in the middle of the track and the rails pull in at that point.
    If you are willing to glue the tack down, you can put headless pins through
    the holes and into the foam, check and test the layout, then lift the track off, apply glue, and drop the track back where it came from.
    Test all glues on the foam before using. One fellow didn't and he made a lowered loading track when the foam dissolved.
  5. Biased turkey
    I'm afraid I didn't make myself clear.
    I don't use the needle ( or a pin ) to pin the tracks down, but just to mark the position of the holes on the subroadbed ( in my case, pink extruded styrene ).
    That's the reason why I dip the needle in black ink before marking every hole in the center of the ties.
    After removing the tracks I have a succession of dots that indicate the track center.
    Sorry for the confusion.
  6. nwdyr
    nwdyr New Member
    No problem! thank you, I am about half way done laying the track, I am using the pins to hold the track in place right now, but I will try what you said about marking the center line for the corck roadbed. And I am also using the ext. styrene
