So, life changes come up and I recently had a big one. Namely I was fired from my job. Not going to mix up this thread with a bunch of sob-stories or explination but I have decided to focus on school and finish my degree rather then getting steady work again. So what does this have to do with this forum? Well I have a decent amount of free time on my hands now. Free time means I get bored which is what started as. A boredom project but as I actually started sinking my teeth into it, it became a challenge. The challenge: To see if I could build the entire titan with out using anything pre-made. No bits, no kits, just paper, card stock, card board, glue, foam core and the like.
The template this is based on is the old school made by JSvironfurnace. It's a nice basic design that provides a solid foundation to build up from. I've toyed with the design several times in the past. This is going to be a serious and sincere effort to make it my own this time.
I give you... the toe!
The toe joint is made from 2 sheets of 5mm foam core glued together. I added additional surface details by pulling the template parts into photoshop, making the details into layers and then printing them out on card stock. It's an interesting challenge cutting out 4 levels of details for something like this.
The toe cup is made out of card board from cereal boxes and then additional layers of details have been added with the application of Card stock.
The foot! So yeah, everything that was the toe, times 4. The... erm... palm of the foot? whatever you want to call it. The section the toes all connect to is made of 3 layers of foam core wrapped in an edge of card board, again from cereal boxes. The ankle mount is a single layer of foam board with a layer of card stock around the outer edges.
I ran across a styrafoam ball and I had an idea for using a ping pong ball for the ankle joint. With no better use for the ball, I cut it in half and mounted it on a form for the top of the foot. Looks rather promising. Will probably use ping pong balls in the ankles for the next titan I build.
Here we have the lower leg. Well a good portion of it anyway.
The shin armor is a good example of what I made in photoshop to add to the template. The jagged arrow edging was made by pulling the template page into photoshop, making a new layer on top of the original part and desiging the edging. I then printed 2 copies, 1 for the base to go onto card board and a second to be cut from card stock. The card stock is just the arrow edging while the cardboard is the foundation of the part. Cut 'em out, glue them together as needed.
I added additional bracing for the mounts to the shin armor.
The ankle joint is made from cardboard. I first glued it to the ankle mount, and then applied a layer of card stock over that and joined that to the mount. It's surprisingly solid.
The pistons were a challenge but I think I pulled them off well. What I did is took Q-tips, cut off the cotton heads and then rolled strips of paper around one end to create the piston look. I was then able to cut through the rolled paper to make it mount in a way I needed it to on the foot.
The leg of the Warhound has a series of pistons going between the leg sections. I added the pistons by building an internal mount for the pistons which you can see here.
The foot as it stands... no pun intended.... now.
