Varnishing cork roadbed???
Discussion in 'N / Z Scale Model Trains' started by bentgen, Jun 28, 2006.
  1. bentgen
    bentgen New Member
    Can someone give me the pros and cons of varnishing cork roadbed before the track is fastened to it? Does it keep the cork from drying out over time and make it last longer?
  2. eightyeightfan1
    eightyeightfan1 Now I'm AMP'd
    Never heard of anybody ever doing that.Considering, that its going to ballasted over anyway, In my opinion, it would be a wasted step.I've had cork roadbed in my attic(Where the layout is)for years, some layed down and unballasted, and with the tempature changes, never had a problem with it drying out.
  3. Play-Doh
    Play-Doh Member
    If you are going to ballast...I wouldnt bother. Heck, even if your not I wouldnt as long as your not living in the desert or something.
  4. bentgen
    bentgen New Member
    I keep humidity in the house above 40% for some musical instruments I have. Hopefully the cork will last longer than I will.
  5. 60103
    If you use the cork for sound deadening, varnishing will probably put the noise back. Even ballasting will, to some extent, if the ballast glue links the track to the sub-roadbed.
