USS SULACO & PATNA by Tomys / Jan Rükr / 1:430
kingofprd
24
Czech Republic
Hi, I build all three versions. Is printed on a laser printer paper 200g/m2.
Brown Sulaco without modification. Patna is the experimental treatment and blue Sulaco is my flagship, which will use the proven treatment.
Dropship, which I taped a long time.
Well, the first part is printed.
Additional model is designed for the model Sulaco3 gray-brown and has a form of escape pod BD409-EEV. The worksheet is also the second papercraft (destroyed after landing) version of the EEV envelope, including the covering vystřeleného sulaca side in place of separate modules from the ship.
juntopi
31
Internal structure
Nice! In the last few pictures are those internal supports just strips of 200g/m2 cardstock?
Tirick
369
20
18
Ontario, CA
tcfgaming.com
You are very, very brave.... :mrgreen:
With a laser printer Jan's textures will pop in all of their gorgeous glory. Those will look incredible once done, of that I am certain.
Tirick
Hot4Darmat
173
Kingston, Ontario
Wow! Beautifully executed parts. You are indeed very ambitious. I'm making only one, the dark gray Alien3 version of Sulaco, and this will likely tax my time/paper/ink capacity to the limit. All 3?! My hat is off to you.
kingofprd
24
Czech Republic
Other parts. The only problem will probably be the place where the tooth is a red line. According to lines of work should be larger. I'll see how things turn out.
KGC
33
ITALY
I also noticed this problem while I mount my model, how do you think could be solved?
We should ask Jan if you have had problems.
kingofprd
24
Czech Republic
The problem is, most builders USS Sulaco. Now you can download a new set of parts according to which if you know it's OK. Jan, I will ask.
Marco Scheloske
330
51
31
Germany
www.triliance.de
Last weekend I completed the upper bow, and I discovered another slight problem: The front of the bow.
This group is now, because of the too long freight section, to far behind the front end and will need a spacer later, too, just like the lower bow at the aft end:
Jan, will you adress this issue, too?
Marco Scheloske
330
51
31
Germany
www.triliance.de
Yesterday I discoverd that group 9 don't fit, too - what is only logically, because group 8 is longer than it should be because of the gap (that was already adressd by Jan).
Well, no big deal, as the same method (a cardboard spacer, camouflaged by texture) can be used here, too.
But I must say that I'm VERY happy that Jan is constructing the model in large groups - that way such little errors won't have an influence to the whole ship and can be corrected easily.
I`m curious what todays upload will bring. Those fridays are really exciting - everytime like a little christmas!
Jan, I cannot say it often enough: Thank you for this paper modeling gem!!!
