USS Stargazer
9,559
Get out of the loop by typing -pinterest in your query. Also, look under Google images. :)
spaceagent-9
Right Hand Man and Confidant
3,116
3,480
143
62
pheonix
It you do that particular model, I would recommend the you cut the upper hull into 2 sections, one an outer ring outside the N.C.C. Number and then two, the slight tilting plate that goes up under the bridge assembly. Otherwise it will look weird.
