Up the tunnel
Discussion in 'FAQs' started by Woodie, Sep 28, 2004.
  1. Woodie
    Woodie Active Member
    What do you guys do inside your tunnel entrances? How far up do you ballast/weather the track and do you enclose the area inside the entrance?
    I've heard that crunching up (then flatenning out) aluminium cooking foil and painting it black and lining inside the tunnel entrance makes for a good "rocky" look when you look up the entrance. Wouldn't that puncture easily from derailments or extraction attempts of derailed rollingstock?
    The first bit of landscaping Garahbara is gunna be "over the back bit" when the mainline exits a tunnel and rounds a riverside embankment.
  2. sumpter250
    Whenever I put a tunnel in, I try to provide access to the inside...just in case. The tunnel on the club layout's narrow gauge section is only 140 scale feet long, and is timber lined the whole length, and plastered in. Extrications here are done ...very carefully.
  3. TrainClown
    TrainClown Member
    Hi there Woodie :)
    There are molds you can get to cast tunnel liners out of plaster. Or you can make your own tunnel liner by using crumpled foil as a mold and casting thinnish rock pannels that you can hot glue into the tunnel liner.
    Tunnel liners make all the difference. Foil is weak, so use it only where the trafic will be low.
    Here is my foil cast rock display. The tunnel liner is the cast-on-foil way, but I enclosed the end of the tunnel to make it dark with just a piece of foil as this is just a display.
    If you look you can see how the foil still reflects light and there is a defonate difference in the plaster wall and the foil end. You can also see the pin holes of light from behind. I made the rock face of the cliff out of foam, covered with a base coat of plaster, then a stiff coat of plaster and pressed on the crumpled foil. I'm still working on this display. The colors are not right yet. :rolleyes:
    TrainClown :wave:
  4. jwmurrayjr
    jwmurrayjr Member
    I provide access panels on the fascia. These are secured with Velcro.
    I just "finish" the tunnel with some dark paint and some sort of texture (foam or crushed foil) just as far as you can see from a normal angle. Painting the rest black and keeping out stray light helps the effect.
  5. Doc Holliday
    Doc Holliday Member
    Hey Jim,
    Whose toys are those piled under your layout?
  6. SteamerFan
    SteamerFan Member
    oh you had to go and ask, we all know they're Jim's ;)
  7. Lighthorseman
    Lighthorseman Active Member
    I've seen a few (in magazines and in person) tunnel accesses done as shadowboxes, and the effect is very impressive. Something to ponder. :thumb:
  8. Fred_M
    Fred_M Guest
    I too have seen one like that and it's great. Someday I may go back and redo my tunnel as a shadowbox. The one I seen had a plexiglass cover and wonderful timber lined interior with a trak crew working with led lanterns, and a dinosaur bone in the rock above the tunnel (but behind the plexi). The plexi was hinged to allow clearing the tunnel. Was a real nice scene. Fred
  9. jwmurrayjr
    jwmurrayjr Member
    Well...er...uh... :oops:
  10. Doc Holliday
    Doc Holliday Member
    Hey Jim,
    I was wondering when you'd check back in. :D
    Don't worry, we all have our little secrets. Look on top of the TV in the corner. What's worse is they talk to each other.
  11. spitfire
    spitfire Active Member
    Doc, I love the stencil on the duct-work. I don't see any forehead-shaped dents there though! Just goes to show you, no one ever reads instructions!!! :D
  12. docsnavely
    docsnavely Member
    your basement looks awesome! Everything on the ceiling exposed as it is looks like the berthing compartment on my last ship......except the stenciling of course! :rolleyes: !!:D
    -doc (the other one):wave:
  13. Doc Holliday
    Doc Holliday Member
    Hey Doc (the other one),
    Having a basement to work in is great, except for the low ceiling (which results in the low duct work). My house was built in 1915 and it's amazing how much crap (wires, pipes, cables, ducts, etc) runs through the basement. A lot of it has been abandoned over the years with numerous home improvement projects and is no longer in use. I've taken quite a bit of it out or rerouted it around the outside walls. It also looks a whole lot better after I painted everything white, and I mean everything. I masked off the windows, water heater and furnance and let her rip with the air sprayer. While the ducts are gonna have to stay, I plan on redoing one duct junction box that's right in front of the layout and will live with the rest.
  14. lester perry
    lester perry Active Member
    Wait a minute here guys. I am missing something here I can't find any pics of Docs layout
