UHU02's Viper MK-II (REBUILD)
9,924
It is time for the landing gear.
Here are the components for the landing gear.
As you can see, I opened the elliptical slots on the sides. I raised the hinge pins and the part on top.
The main tube is attached.
I raised other detailed parts to give it a bit more of a realistic feel.
The front landing gear strut is finished.
All three are now finished (with the same details).
The landing gear is attached.
9,924
Here are the ammo racks that go in the wing struts. Since this is an "overhaul", I got rid of the "bullets" by taking the under panel, cutting the holes out, and using it fo the top of the panel, so there are no "bullets" visible.
The ammo racks are attached.
20180908_161010.jpg 20180908_161018.jpg 20180908_161028.jpg 20180908_161034.jpg
I permanently attached the landing gear as well.
9,924
As some of you have guessed, I have plans to build a large diorama of a maintenance hangar bay. However, in the interim, I have decided to rebuild my original diorama (ANOTHER FRAKKING OVERHAUL). There will be a few changes though.
Here is the platform. I have added the squadron patches and raised the lettering.
20180910_201041.jpg 20180910_201049.jpg 20180910_201056.jpg 20180910_201106.jpg 20180911_211927.jpg 20180911_211939.jpg 20180911_211951.jpg
9,924
I mentioned in my last post that there are going to be a few changes to this diorama.
Here is one of them. These are aircraft jack-stands designed by @sakrison.
20180911_124018.jpg 20180911_124144.jpg 20180911_124244.jpg 20180911_124317.jpg 20180911_124516.jpg 20180911_212444.jpg
I now return you to your regularly scheduled programming. Please stay tuned to Colonial Fleet News for further updates as they come.
9,549
Very nice. Love the jacks!! ;)
9,924
Now on to other interesting components for this mini diorama.
Here is the Mule Tractor (designed by @silveroxide which is available in the Resource Section). Now, I did make a few changes and added a few things.
Starting with the tyres. I followed @silveroxide's recommendation of wrapping strips of paper around a dawl until you get the right thickness. I also raised hub so that the "black areas" look recessed.
Here is the chassis.
Here is the body
20180915_142329.jpg 20180915_142341.jpg 20180915_142349.jpg 20180915_142355.jpg
I raised the circles and the rectangles in the center, and recessed the larger rectangle.
The panel is attached.
I raised the center light panel with the red lights and attached the "caution" panel.
I enhanced both the front and back bumper.
9,924
Now for the rest of the details.
I added side panels to the seat.
I attached the main and side control panels, seat, and steering wheel.
I decided the add axles to the wheels for a more "realistic" look.
I covered the axles to help with holding everything in place.
The little Mule is now finished and added to the diorama.
9,549
Now I see what you meant about the cart, it came out great!! ;)
Reactions: Rhaven Blaack
9,924
Here are few more components: A handheld tool box, equipment cabinet, and flight ladder (designed by @silveroxide.)
For the tool box, I raised the drawer fronts and made an actual handle.
With equipment cabinet, I recessed the handles, defined the wheels to make them look more like wheels, and raised the framework.
I am really not that happy with the flight ladder. I think that the side rails are too wide.
The components are added to the diorama.
20180920_183258.jpg 20180920_183315.jpg 20180920_183952.jpg 20180920_183959.jpg
9,549
I wouldn't worry about the ladder, as when it is placed in the diorama, it really looks good, the sum of the whole being greater than the parts. :)
9,924
Here is some "furniture" for the diorama.
Here is a simple work bench. I raised the matt on the table. I also re-enforced the supports for the legs.
20180921_112521.jpg 20180921_112529.jpg 20180921_112539.jpg 20180921_112550.jpg
Here is a stool and chair. I added the BSG logo to both the stool and the back fo the chair.
Since the Viper is on jacks, I decided to make a stool and have the maintenance crew on the stool, instead of lying on a creeper crawler.
I re-enforced the back post of the chair and the back "cushion" to give it a more "realistic" look.
The furniture has been added to the diorama.
subnuke
Banned
Nov 18, 2007
283
188
48
That's not an overhaul that's a restoration! Looks like they found that at the bottom of a river decades after a war. Nicely done.
