two couplers
Discussion in 'N / Z Scale Model Trains' started by belg, Nov 25, 2003.
  1. belg
    belg Member
    Guys I'm trying to make myself a car that has both Microtrains coupler and the old style coupler I'm using a gondola which I weighted and figured because of the low center of gravity would be a good choice for this type of car. My problem is that the micro coupler fits so loosely on the pin that it flops around if I had a washer that fit the post it might help but the one they give does not fit. I've tried all the combos that came with the coupler kit and it still keeps derailing.It is an aurora trix car. Any advice????
  2. Sir_Tainly
    Sir_Tainly Member
    You could make a washer from a piece of styrene with a hole drilled in it.
  3. Arlaghan
    Arlaghan Member
    You could try to use a paper shim.
