Train Jerking
Discussion in 'HO Scale Model Trains' started by wpyr, Sep 3, 2008.
  1. wpyr
    wpyr Member
    Hi I have a Ho model of CN`s 6060 and every time I run it at a low speed it makes lots of little jerks. I have Atlas Gear lub but does anyone have any tips? thanks
  2. doctorwayne
    doctorwayne Active Member
    Steam locos have lots of places that can cause operational problems. :rolleyes::-D In addition to the problem of dirty wheels (and track), there are numerous places in the drive rods and valve gear that can cause binding. Many models also split current collection between the loco and tender, which means more places for something to go wrong. It might help to narrow things down a bit if we knew a little bit more about your loco, specifically, who makes it?
  3. wpyr
    wpyr Member
    well the train brand is some wierd thing:111ehno. Thats what it says on the bottom slong with made in slovenia.
  4. doctorwayne
    If it runs okay at relatively normal speeds, it may be the nature of the motor - many of the more cheaply made locomotives use a low-quality, three-pole motor, and these are not known for their smooth, low-speed, operation. ;):-D
  5. 60103
    Is this the President's Choice train set?
    Further to Wayne's comment, with cheap motors with few poles you get an effect called "cogging" at very slow speeds as the motor zips one pole to the magnet then holds a bit and then zips another pole to the magnet. (very simplified explanation). This wold give many jerks per wheel revolution.
    Do your jerks match the wheel revolutions (or twice a revolution)? That would suggest mechanical binding. If the loco keeps going deoite the jerks, it's probably not dirty wheel-rail contact.
  6. wpyr
    wpyr Member
    Yes this is the pesidents choce set. I think your right with the magnet thing. Thanks!
  7. jeffrey-wimberl
    jeffrey-wimberl Active Member
    Made in Slovenia? Sounds like Mehano.
  8. Dave Harris
    Dave Harris Member
    Time to remotor it. Get a good coreless motor & it will run smooth as glass.
