Traction tire keeps slipping off my O gauge Weaver 0-8-0
Discussion in 'FAQs' started by munnone, Jan 6, 2003.
  1. munnone
    munnone New Member
    I own a Weaver c1 0-8-0 and the traction tire keeps slipping off of the driver wheel on one side of the unit. I have tried the obvious by replacing the traction tire with a new one.
    I have also carefully inspected the driver wheel itself and the machined groove appears intact.
    Has anybody run across this problem and if so, are there any suggestions as to how to correct it ?
  2. Vic
    Vic Active Member
    I used to solve that problem on AHM HO locos by spreading a very,very thin coat of silicon glue on the driver tire, then re-install the traction tire and let the whole thing dry overnight....Silicon glue takes a long time to dry.
  3. pcentral
    pcentral Member
    Hi and Welcome to the Gauge,
    I had the same problem on a set of K-Line interurbans I had. I solved it by removing the traction tire and wiping it off thoroughly. Then I put a thin coat of Goo on and replaced the tire. Clean off any extra and allow it to dry. That did the trick for me and it should for you too. Steve
  4. 60103
    Has anyone filled the traction tire groove with epoxy, then levelled it off? I thought of doing that once, but never had the nerve.
