Thunderbirds are go, er well, sort of....
9,558
I'd consider cutting out the windows, and using a darkened plastic, for depth, or not, just an idea. ;)
Reactions: Cybergrinder
9,558
You wold cut the windows after you attach the section is front of them. If you re-enforced the inside of the windows with some heavier stock, then that section would hold up.
9,558
That model is smaller than I thought!! :)
9,558
You'll be able to respond to all the mini crisis in the world. Lots of responsibility there!! :)
Sky Seeker
Well Established Member
Jun 1, 2015
1,178
1,083
95
Thanks for the suggestions Zathros, but I'm going to keep as is for now. (Maybe if I do a rebuild at sometime)
So, cockpit nose attached
Then the engine intakes - here's the parts
And assembled
And attached to the hull. II really like the fit overall look of these parts :)
I have to concur with the others this is definitely my favorite of the thunderbirds.:)
Nice work!:Bravo:
Sky Seeker
:tank:
9,558
That's really coming out nice. The framing for the pods looks great! :)
