The "Original" Kittom Lumber Company. Part #2
9,558
Circlips for lifting tongs!! Brilliant!! :)
Doctor G
1,415
298
Clarksville, Tennessee
Putting the finishing touches on the mini logging layout.
I painted the river and stream bottoms and their shorelines using acrylic paints.
Using an interesting product Dave Frary liked called “ModPodge” I applied the river and stream surface using a fan brush.
Following are pictures of the completed streams and river.
I would appreciate your comments on this product / technique and if you have ever used it to create river and stream scenes.
Thanks for looking. Doc Tom
Gandolf50
1,327
1,576
96
New Mexico USA
It looks very nice! I always found Modpodge to remail a bit soft and slightly sticky ( used it over decals and images on board or woodworks). I always used a casting resin in 3 layers minimum, tinting each layer from dark to light with a hint of green and blue, up to a clear top coat... Adds a great deal of depth but is messy and takes a long time, as well as a risk that it will warp from the heat produced and pull your layout apart. As far as your technique, apart from the lack of visual depth ( judging by the pix here), the effect is virtually the same with a great deal less work or mess!!
Doctor G
1,415
298
Yes, it is not so messy. Particularly with the water effect at the very edge of the mini layout I elected to hold off on the casting resin. I have like you successfully use the casting resin in the past. Doc Tom
Reactions: Gandolf50
Bill Nelson
2,680
467
Clarksville Tn
I have used acrylic gloss medium , which is similar to Modpodge in the past. On my big river , my riverboat would stick to it, so I’m going to use epoxy on my new big river.
Doctor G
1,415
298
One of the fun parts of modeling in On30 is the "mini scenes" you can do with lots and lots of details.
Well the steam locomotives need a lot of cut wood to do their work......so a mini scene on the mini logging layout.
Thanks for looking.
Doc Tom
