Switched Scales, need specs.
Discussion in 'N / Z Scale Model Trains' started by Will_annand, Feb 27, 2004.
  1. Will_annand
    Will_annand Active Member
    Well, I decided to switch scales before I start my layout.
    I just could not get that much into a 5' x 11.5' space. In N scale I can get much more.
    I am attempting to design a new track plan. What I would like to know now is the specifications for N Scale.
    1. What is the track guage in MM?
    2. How long would a scale mile be?
    3. What about inclines?
    4. What is the spacing between tracks on the straight?
    5. What is the spacing between tracks on a curve?
    6. Anything else I need to know about N vs HO?
    Any help would be appreciated.
  2. sumpter250
    1: 9mm
    2: 33 feet (10.05831 M)
    3: Inclines would be the same in any scale, h/r X 100 =%of grade, where h = the height, r = the run, or length in which the height was attained.
    4: Ntrak spec is 1-1/2" (38.0997mm)
    5: you can find specs at www.nmra.org/standards
    6:you need to know OptiVisor......... :D :D :D
  3. Will_annand
  4. sumpter250
    Things are a little smaller in N, you might need magnification. I've been using an optivisor for about thirtythree years.
  5. Will_annand
    Ahh, now I get it :thumb:
    One of those "hats" with a lighted magnifier on it...
    I see. Well, I am 50, so I think I will put that on my shopping list.
    Thanks Pete
  6. billk
    billk Active Member
    Geez, read the subject of the thread, guys - he already said he needed specs!
  7. Will_annand
    :D :D :D
    You got me on that one billk. :wave:
