Space probe Voyager
Discussion in 'Space & Aeronautics' started by SeriousNikos, Aug 30, 2012.
  1. SeriousNikos
    SeriousNikos New Member
    Original -Вояджер-1
    Scan -
    Printed from the original sweep across 80%, which was to give 1/32 Model.
    Antenna diameter slightly larger than the CD. Rod and copper antenna reduced to 12-15 cm (you can imagine how he would look with a full-size antenna of 32 cm)
    Assembly time about 2-3 weeks. Launched into orbit under stars
    Printed on a printer Epson R290 + CISS on paper 160 g
    General appearance:
    "Hand" with tools
    Hand tools with a width of 7 x 7 mm is cut through. Block at the end of the "hand" has two degrees of freedom.
    Radioisotope thermoelectric generator and a magnetometer on a boom
    Magnetometer boom - 5 * 5 mm, is made up of 5 cm segments
  2. Zathros
    Zathros Guest
    The whole model is fantastic but that Magnetometer boom is absolutely fantastic!! :)
  3. Space Boy
    Space Boy Member
    It's very beautiful! Well done! ;-)
  4. pulp
    pulp New Member
    oh, wow - real fancy! absolutely well done.
  5. martinsmc
    martinsmc New Member
    Fantastic model, congratulations.
  6. ASC Mclaren
    ASC Mclaren Member
    Amazing build!
