Soldering Iron Warm Up
Fluesheet
339
Central Ohio
Quick question - how long does it take the typical soldering iron to reach operating temp (assuming the tip is not touching anything to sink the heat)?
Thanks!
Fluesheet
jim currie
1,383
arizona
depends on the wattage and the type of iron. I have a 75 watt copper(2 lb iron) that takes almost 15 min. to get hot a small pistol about 15 sec. a 75 watt weller station about 2 min.and a restance soldering tool a second or two.
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
I have several different temperature-controlled irons. The Wellers all take about a minute or so to get to 700 degrees, while the HAKO that I use on the bench heats up to that temp in less than 30 seconds. One pencil iron I have takes a bit longer, somewhere around two minutes. Each iron is going to be different dependent on the manufacturer, wattage and type.
