Sketchup 2017 make
mijob
Tie designer
3,195
5,410
95
Netherlands
Good afternoon all,
I found this tutorial saying that it's possible to get a free working sketchup 2017 make pro edition after 30 day's.
I will give it a try or has anyone already tested it?
This is the link it's a dutch site so you have to translate.
Otherwise I will make a "how to" document if it's working.
12,373
I'm sorry but I cannot see any difference from the usual installer. As I understand it you download the installer and when you install the program it runs in pro mode for 30 days. Then it switches to regular mode. That's how it's always been.
My SketchUp Make 2017 is working for years without issues.
This is how it looks at startup:
Then I click on "Use SketchUp" (the tab in the bottom-right corner on the dark grey bar) to start the program:
Do you mean the paragraph about setting the PC's clock back?
Reactions: mijob
mijob
Tie designer
3,195
5,410
95
Netherlands
No, they say after 30 days of trial the pro edition is still available.
I will see wath will happen.
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Good afternoon all,
Are you a Blender user?
spaceagent-9
Right Hand Man and Confidant
3,116
3,481
143
62
pheonix
The only problem I had back in 2017 was that because I didn't buy the software it refused to save the project and turned it inside out like some kind of horrible transporter accident.
  • Wow
Reactions: mijob
mijob
Tie designer
3,195
5,410
95
Netherlands
Update for this topic.
After 30 day's of trial the pro edition is no longer available.
But you can still run the 2017 make edition.
Reactions: Rhaven Blaack
