Scenery advice sought...
Discussion in 'Getting Started' started by EngineerKyle, Aug 31, 2007.
  1. EngineerKyle
    EngineerKyle Member
    Say, I posted this on another train forum. I’m looking for advice on how to complete this derrick scene.
    The cone of sand is just that, I found a metal cone with a profile I liked, and painted it with tan, flat latex. Then I sifted beach sand over it.
    After gluing the cone and other structures to a board, I put a thick coat of paint on the base board and sifted sand over the rest. I like the way the sand gathered around, but I know that when I shake off the loosen sand, those lovely dunes will be gone.
    My plan is to spray it with window cleaner to break up the surface tension, then soak it with 50/50 white glue, ala ballasting. I’ll bet there’s a quarter inch of sand under that derrick. Will gluing it this way work? Will the sand glob up when I spray it? I don’t want to ruin it.
    Thanks in advance...
  2. MasonJar
    You can use isopropyl alcohol to soak the sand first. I have ballasted, and "built" piles of coal this way.
    The isopropyl alcohol is available in a 50 to 70% solution at the dollar store - no further cutting with water is required. Then soak it with your glue mix. Just make sure that it is very smooth and is given enough time to really dry.
  3. EngineerKyle
    EngineerKyle Member
    Thanks Andrew,
    I did like you said, came out fine...
    Here is the overall scene;
  4. Ralph
    Ralph's for fun!
    That looks great!
  5. Herc Driver
    Herc Driver Active Member
    WOW! That really does look great!
  6. N Gauger
    N Gauger 1:20.3 Train Addict
    Nice!!!!!! :thumb: :thumb: :thumb: :thumb: :thumb:
  7. nachoman
    nachoman Guest
    Holy crap Kyle, I thought that was real for a second!
  8. doctorwayne
    doctorwayne Active Member
    Nice work, Kyle, and a nice photo, too! :thumb::thumb:
  9. TruckLover
    wow that looks awesome Kyle!!! Very Nicely done :thumb: :thumb:
  10. UKSteam
    UKSteam Member
    Wow is right and if I may use a slang from back in the UK , I'm absolutely gobsmacked !!!
    That is a beautiful job done on that project. Yes it does look like a photo' of the real thing. Well done indeed on that EngineerKyle.
  11. MasonJar
    Glad the advice worked out (phew!).
    And for the record - I was fooled for more than a few seconds...! :thumb: :thumb:
  12. CNWman
    CNWman CNW Fan
    Same heresign1 although I bought it for 10 seconds untill I saw that 'all trucks' sign...:rolleyes::mrgreen:
