S.M.S. Emden, HMV, rescaled 1:200, self designed hull
nibel
51
Malaysia
I plan to make Emden earlier but now I think I will just wait and see... impressive work Flu! Especially for teh gun. I never able to make gun in such small size...
Jim Krauzlis
1,490
Copiague, Long Island, New York
As usual, superb work, Flu!
That's quite an amazingly clean and neat looking hull, brilliantly done. The small gun is really an amazing bit of paper modeling magic!
I can hardly wait to seem further updates on this build as you proceed!
Thanks for posting photos of your excellent work!
Cheers!
Jim
the hull is nearly closed.......
Hi Folks,
just have a look at the nearly closed hull,.......O.K. some gaps have to be filled in the next steps.....................the overall impression ins´t bad.........
FLU
Notice: The main deck must be doubled with cardboard it´s not stiff enough, so it´s realy uneven............we will see how it will look like during the next steps.
Jim Krauzlis
1,490
Masterful work, Flu!
It's great to see the hull come together so well, mate!
Not sure what gaps you are referring to, I didn't see any in the photos.
Interesting construction on the foredeck structure, can't wait to see how this works out.
Keep at it, mate!
Cheers!
Jim
the uneven deck.......and it´s revision......
Hi folks,
I´m proud to tell you how I improved my eneven deck................
Firts I built the deck-boxes and glued it to a new deck. Aligned to the inner bulwark........
After that I dismounted the uneven deck, very carefully, not to destroy the outer bulwark !!
Finally I assembled the new unit well alligned to the outer bulwark......and it works :thumb::thumb::thumb::thumb::thumb::mrgreen: just as reflected last night.......:eek:ops:
so, now I´m satisfied with the work so far .........................
best regards FLU
Thank´s guys for the kind words,
meanwhile I made some progress.............
the middle casemate artillery is finished.........
the hull is finished and closed too
the shape of the hull is absolutely racy it seems I can feel the power of that vessel..........:thumb:
the first superstructure
best regards FLU
the first funnel.....
Hi folks,
I just made the first funnel including it´s funnelrings, but how to do without etched parts?
Just have a look:
the columns are made of doubled cardboard
glued exactly at the markings of the printed funnelrings
the ring is made of plastics
assembly is rather easy.......cutting and glueing all the columns is boring
but the result is more than compensating......
it´s nice isn´t it ?!!
best regards FLU
selfmade railings.............and the Bridge
Hi folks,
to become independent from etched parts, I tried to make my railings by myself.....
I show you my first attempts:
Fist step is to cut out a "comb" of cardboard, hardened by plastic glue, then I glued plastic fibres on that comb.......
last step was coloring by alkydcolor, what´s your opinion, is that a alternative?
O.K., next step was the Bridge..........
macros are so bad...................
best regards FLU
