S-51 WoT in 1 / 50. Construction report.
Dagger
215
456
40
20180924_060617.jpg 20180924_221442.jpg 20180924_221458.jpg 20180925_055933.jpg 20180925_120348.jpg 20180925_193341.jpg 20180925_193326.jpg 20180926_111256.jpg 20180926_211355.jpg Greetings. As I publish in my presentation the WoT designs are to my liking and my best works. This model I built a few months ago, I show them step by step so they know my way of building. I like to see reviews, opinions, advice, etc. I think that the construction processes are the best guide to learn and improve our constructive techniques. In my case, seeing the work of others significantly improves the quality. So here I present my first thread. The first photos show the construction of the helmet, consists of two pieces, reinforcements and several pieces that make up the sides. Always reinforce this stage with cardboard, recycled, 1 or 2mm to give rigidity. Nothing spectacular this part, just fold, reinforce, paint edges and join.
Dagger
215
456
40
Tengo problemas para publicar. Primero, no sé si el texto está traducido, segundo, aunque inserto el texto copiado del traductor al principio y luego subo las fotos, ¿qué estoy haciendo mal?
La segunda parte, el apoyo del obús, ni nada espectacular, solo van uniéndose con paciencia.
Reactions: zathros
Dagger
215
456
40
Now the train, here the thing changes, several pieces, wheels, rollers, chains, very entertaining. To join the rings I always cut the tab and put it behind, I do not like it to be over, so it is at the top and much better. The wheels always drag, it gives more realism to the model.
20180928_060622.jpg 20180929_184910.jpg 20180929_233616.jpg 20180929_221138.jpg 20180930_092220.jpg 20180930_153310.jpg 20180930_215937.jpg 20180930_130803.jpg 20180930_112912.jpg 20180930_112953.jpg
Dagger
215
456
40
More than the taxi train. Some pieces that I guess would be something like the suspension I think. Setting the wheels, here you have to pay attention, the WoT designs have an effect of lights and shadows that give a 3d effect, according to how they are oriented. You have to imagine how the light of the sun illuminates, that is, from above, back or front and orientate the wheels all in the same way. This was not discovered, I was told, in M53 / 55 I did not perceive this and I was different. In the S-51 this effect is not, but a discoloration in the wheels.
20180930_223454.jpg 20181001_064203.jpg 20181001_200054.jpg 20181001_200039.jpg 20180930_215959.jpg 20180930_223115.jpg 20181001_221222.jpg 20181001_221143.jpg 20181001_221232.jpg 20181001_221519.jpg
Dagger
215
456
40
[Caterpillars or chains. In these designs is simply a piece that bends and sticks in half. Mark each link to move a bit gives something more realismo.Utilizo a better system and allows you to give the whole look much more natural and realistic It is somewhat laborious but it is worth it. I found the system in a publication of a colleague who in turn saw it on the Russian VK page. First link is cut by link, the edges are painted, they are folded in half and they are As a guide or template I use a simple cardboard of 2mm, according to the width of the chain I put 2 or 3 common threads of haberdashery, well parallel, equidistant and tense. Then I simply introduce one half of the link below the threads, I apply PVA in the other half and I join one by one. It is simple, it is very flexible and we can place the chain as we think best.
ATTACH]169922[/ATTACH] 20181002_221936.jpg 20181002_221916.jpg 20181003_122131.jpg 20181003_182045.jpg 20181003_182122.jpg 20181004_120430.jpg 20181004_120400.jpg 20181004_120418.jpg
Dagger
215
456
40
As I went forward I found a problem. Where the shell is in the simple version, it is only a flat surface, in the detailed version it should have a well to allow more elevation angle to the howitzer. The drawings do not show this detail, they indicate it in the text that is in Russian.Tenia 2 options, leave it like this and subtract detail from the model or try major surgery: remove the base of the howitzer, fill the gap, cut the chassis, insert the piece underneath, close the chassis and place again the base. I decided for the latter and I succeeded. The change is remarkable.
20181004_213740.jpg 20181004_222252.jpg 20181004_222852.jpg 20181004_221031.jpg 20181004_224717.jpg 20181004_230319.jpg 20181004_225231.jpg 20181004_225241.jpg 20181004_225507.jpg 20181004_225311.jpg
Dagger
215
456
40
Solved this part we continue adding details, support of the howitzer and other things that I do not know what its name is. I hope to be publishing well, I have a hard time understanding this (my computer skills are very poor)
20181005_122811.jpg 20181007_084151.jpg 20181006_170421.jpg 20181006_170410.jpg 20181006_170346.jpg 20181005_210457.jpg 20181007_084151.jpg 20181007_172605.jpg 20181007_172537.jpg
Dagger
215
456
40
A few more photos of the support. Then the howitzer, funny part, several pieces, the shooting chamber, the cannon, the hydraulic cylinders and other things. For cannon tubes in this scale the best is the common paper of 80-85grs, it is much easier to roll this thin paper.
20181007_172507.jpg 20181007_172456.jpg 20181007_193941.jpg 20181008_124609.jpg 20181008_215021.jpg 20181008_214845.jpg 20181008_214858.jpg 20181008_214927.jpg 20181008_221807.jpg 20181009_061425.jpg
Reactions: lyter1958
Dagger
215
456
40
Por último, la parte complicada. Este modelo tiene un trabajo importante con el cable. WoT recomienda soldar o pegar súper, probar todo tipo de adhesivo, ninguno trabajado, al menor toque desprendido. Si usa soldadura, tengo un título en servicio de radio. audio-tv que nunca hice, así que la soldadura de los cables de cobre está terminada. Si logro uniones firmes con un buen resultado. Y esto tiene más cables que la prisión de alta seguridad que tenemos aquí en Ezeiza, ciudad donde vivo.
Dagger
215
456
40
Y al final, varias fotos, dentro y fuera de mi casa.
Dagger
215
456
40
Dagger
215
456
40
I hope you like the S-51, it's an interesting design. Excuse me if the publication is a little sloppy, I'll learn to move here. Greetings, thank you very much.
9,559
I wondered how these came out. Nice job!! ;)
Dagger
215
456
40
Thank you very much! Very kind for your comments, thank you. I already have something printed in science fiction. In a few days I will begin to build. We will see that it comes out.
Reactions: Gandolf50
