Rogue one Tie Striker design thread
mijob
Tie designer
3,235
5,474
95
Netherlands
In one of the tbreads someone mentiond to use clear vernis on rolled parts I tried it and afcource it works. All the pigment stayed on the paper and its easier to roll the paper.
The midle part is sprayed.
Thank you for this suggestion.
mijob
Tie designer
3,235
5,474
95
Netherlands
And here are some quick shots.
Beauty shot will come at a later moment.
20220810_165132.jpg20220810_165219.jpg20220810_165154.jpg20220810_165236.jpg20220810_165326.jpg20220810_165344.jpg
Now Im working on some template corrections. some parts I have to rebuild to check the fitting. If everything is correct I will start with the building instruction. Oops I forgot that I need to make a stand for this model and for the phantom as well. Still a lot off work to be done before starting with the bomber.
