Resizing & Compressing Images
interurban
4,407
Pickering. Ontario. Canada.
Great Program
Hi Folks I have been using this program ever since Dave posted the link I have also sent it to a lot of friends;)
Greg asked what I had used to brighten one of his great shots.
Hence the reason for bringing this helpful post back to the top.;)
Happy Easter to ALL.
shamus
Registered Member
Dec 17, 2000
3,489
UK
Here's another tip also.
Always scan the photo you require at no less than 300 DPI, this will result in the image being quite large on the screen, but it can be resized/sharpened/brightness & contrast altered without any ill effects.
JPEG or .JPG file formats are highly compressed and unlike other image compression formats does not store RGB values for each individual pixels. Instead, the JPEG format works on luminance averages for 2 pixels at a time. So what does this really mean ?. Each time you load a JPEG image and then save it again as a JPEG image, the same technique is applied and image quality it lost. While this loss is not noticeable the first time if you take an image and save it over 3 times as a JPEG, then view the original, you’ll see a loss in image quality.
When scanning an image in from your scanner, if you plan to alter the image in anyway, its best to save in another format initially, for example, BMP, TIFF, PNG etc. Once you have finished altering your image, then save as a JPEG to keep the image loss to a minimum.
Many people argue that the image loss is impossible to see, but the fact that image loss happens is good enough reason to keep it down to a minimum. For a better idea, and to see this loss, load an image in, then save as a JPEG, reload this saved JPEG, then resave it as a JPEG again. Repeat this about 10 times, then view the original image compared to the JPEG.
Saving a JPEG image as a JPEG again once or twice will result in little noticeable loss, so if you plan on altering your images over multiple sessions, saving the image as JPEG, then altering it again at another time, it is best to have your images in another format other than JPEG and when you are happy you wont be altering the image again, then save it for final storage as a JPEG.
Shamus
RailRon
1,602
Trimbach, Switzerland
Another excellent freeware graphics program which handles (and converts) almost every possible graphics version is the IRFAN VIEWER.
Of course you can also resize and trim pictures. (And apart from this you can also use Irfan Viewer for playing sound and movie files. All the needed plugins are also free for download.)
Here is the home page of Irfan Viewer
And Paul, thank you for your informations. Until now I didn't know the compression mechanism of JPG. But now I understand why there is a loss in picture quality.
Ron
