Rare and Obscure Decals
Discussion in 'N / Z Scale Model Trains' started by Agatheron, Nov 17, 2003.
  1. Agatheron
    Agatheron Member
    One disadvantage I find at the moment is locating both locomotives and rolling stock that are consistent with the markings that I see around the places where I live. Locomotives are coming, I have both a CN SD40-2 under my belt, as well as the new Via P42DC...
    However, one label I've seen on a number of Canadian 23,000 gallon tank cars and covered hopers is "Procor" which is quite rare, even in HO. Any suggestions? Even Microscale Decals doesn't have Procor... :(
    It's not hugely important, as black tanker cars are not all that rare. Compromise is the watchword for the moment...
  2. Tyson Rayles
    Tyson Rayles Active Member
    You can make your own water slide decals on your computer.
  3. Agatheron
    Agatheron Member
    Silly me :rolleyes:
    Does this work on an inket printer? If so, how does it handle doing white decals on a black background?
  4. Tyson Rayles
    Use white decal paper and outline it in black (or whatever the color of the car or loco is). Btw way you can scan the car or loco into the puter if you need to do a color match. Micro mark sells a treatment to put on the decal paper if you use a inkjet instead of a laser printer. I use both but I don't use the treatment, however the inkjet decal are more fragile if you don't use it so you have to be careful handling them. Once they are applied to the car and have cured you can spray a couple of coats of Dull-Cote on em' and they are then bullet proof.
  5. txcavgr
    txcavgr Member
    Jim at highball graphics has some. he only has one N scale set at the moment, for doing the Procor LPG cars which I am dying for in N!!!
    http://www.mgdecals.com/FN-135.htm so that will give you the Procor logo.
    Jim will also resize sets for you, email him. He has a bunch of HO Procor sets. http://www.mgdecals.com/procor.htm
    He does really nice work. All of the St. Lawrence & Atlantic decals I have are from him, and he has oddball stuff like M420's and tons of shortline cars.
  6. Clerk
    Clerk Active Member
    Tyson, Thanks for that tip making white decals.
  7. Tyson Rayles
    Dick thank Catt, I was to dumb to figure it out myself! :eek: :D
  8. Clerk
    Clerk Active Member
    That makes two of us.
  9. Agatheron
    Agatheron Member
    Thanks to all on all counts! Procor Decals! Excellent... Now to get cars to put them on...
    Speaking of rolling stock, any preferences as to what is good and what to stay away from brand-wise? I was looking at Budd passenger cars for Via, Model Power and Con-Cor being the two I saw... I'm currently favouring the Con-cor by far... Although I have a line on some HEP-2 N-Scale Via decals... :)
  10. GNRail
    GNRail Member
    This is another source for Procor sets in N and HO. They are the Canadian wholesaler but they should be able to tell you who you can order them from.
