Rail Grinder
Discussion in 'The Real Thing- North America' started by DanRaitz, Apr 9, 2003.
  1. DanRaitz
    DanRaitz Member
    I took these shots today at Deer River, MN on the Lakes Subdivision of the BNSF. I was on my way to Bemidji MN for the local club meeting and when I saw this I just had to take some photos.
  2. DanRaitz
    DanRaitz Member
    Close up
    Heres a closer shot of the front.
  3. interurban
    interurban Active Member
    Dan That`s a super picture. It sure is a mean looking beast.
    Thanks for posting ;)
  4. Dave Flinn
    Dave Flinn Member
    If you really want to see sparks fly, try to catch one of these beasts in action, especially in the dark! I was fortunate to get a glimpse once. Wow!
  5. N Gauger
    N Gauger 1:20.3 Train Addict
    Nice Shots!!!! :) :D :)
  6. railohio
    railohio Active Member
    Here are a few shots of the Loram unit in action.
    The top photo is of the unit parked in Bryan, Ohio waiting to to out for the day's work and the second shot is of the unit grinding in Butler, Indiana.
  7. RailRon
    RailRon Active Member
    I don't quite understand: what is smoking on the pic?
    For me it looks like the weeds on the ballast were burning :eek: (ignited by sparks of the rail grinder???), and from the tank car ahead of the caboose (??) a water sprayer is used to extinguish the weeds again. But then the ballast in the foreground looks quite clean and not charred in any way... :confused:
    Do I misinterprete the picture? Can you enlighten me?
  8. Greg Elems
    Greg Elems Member
    What you are seeing is the dust. When they grind the rail, besides starting fires, it puts fine particles of iron, rust and what ever in the air. Some where on the web, I saw a picture of a rail that had been freshly ground. Really an interesting pattern on the head of the rail. They have a dozen heads or so for each rail. That is how they get the proper shape back on the rail. Also, part of the dust would be the heads slowly disintegrating. Hope this explanation helps.
    Greg Elems
  9. CarlFidy
    CarlFidy Member
    Running in reverse???
    Looks to me that the unit is running in reverse in the picture(ie: the caboose is leading). Looking at the water the tank car is spraying, the ballast in the foreground looks dry. Ballast behind the water spray looks wet, like they are watering first to moisten(sp?) everything up, to prevent fires before they start.
  10. Vic
    Vic Active Member
  11. interurban
    Hi Vic, That`s a neat link.
  12. Matthyro
    Matthyro Will always be re-membered
    Great photos Dan and Brian. A model of one of these whould look great on my layout. A shell could be used over a track cleaner.
