PWM Controllers
Discussion in 'Getting Started' started by Woodie, Mar 24, 2001.
  1. Woodie
    Woodie Active Member
    Can anyone tell me if there is advantages using PWM (pulse width modulation) controllers over the standard variable voltage controllers?
  2. shamus
    shamus Registered Member
    Woodie, Using a pulse modulated throttle makes older open frame motors behave in a better fashion, they lock onto the motor. Standard throttles just supply what I call lose power. The modern motors of today do not need a modulated throttle, especially the Kato and Atlas motors.
    Also, using a pulse throttle makes motors run far too hot.
  3. Woodie
    Shamus, thanks for the info. Don't DCC decoders use PWM?
